Page 1 of 6 123 ... LastLast
Results 1 to 25 of 143
Thread: My new project
    Dec 2009
    St. louis MO
    Wink My new project
    Well I started tearing into this '79 tonight. The body is in great shape but most rubber is harder than a guy on prom night. I need to update some photos these are from the guy I bought it in Texas from.
    Dec 2009
    St. louis MO
    A few more.
    Looks nice, what are your plans?
    1979 capri, a mess, 86 efi
    FEP Power Member Tar 71's Avatar
    Mar 2004
    Southern IL
    Good looking car, a very nice platform to start with.
    86 GT 363 w/80mm turbo-currently under construction
    12 F-150 FX4 Supercrew- DD
    Dec 2009
    St. louis MO
    Quote Originally Posted by mutantcapri1979 View Post
    Right now the plan is basically a restomod depending on the parts I can find or afford. My son is 10 and he is showing some good interest in playing with cars or I'm not sure which is good.
    I'm really happy with the foundation so far. It came from Dalls TX and I got it for $250 + $200 for gas plus it's an original V8 car to boot.
    Dec 2009
    St. louis MO
    I started sanding the body down and this will be a job. I have to take it down to bare metal and we are finding a ton of dings and a lot of putty. Nothing broken through just more work than I wanted. The roof is the worst being so thin and flimsy.
    Jul 2005
    Medicine Hat, Alberta,Canada
    We have almost identical projects. That's pretty cool. I wish I would have found a factory V8 car. Keep up with the post.
    -Currently Foxless unless the right 79-93 notch comes along.
    Dec 2009
    St. louis MO
    Quote Originally Posted by Blainer View Post
    Yep I'm still drooling over your door panels I asked about you restoring. My car is originally a blue interior car and I like your upper panel inserts.
    Nice project!! Are those Steeda subframe connectors? It looks like the floor pan had a crack at the seat mount and was welded. My '79 cracked there, which is common. I had it welded and had some sheet metal strips welded on the inside to reinforce the thin seat mount area. It's still good after 20 years.
    - CA car, 5.0 w/5 speed
    Dec 2009
    St. louis MO
    Quote Originally Posted by banzaibullitt View Post
    Yes sir they are! When I get closer to getting chassis worked on I'll check everything out after I find out what is weak on this year car. Any other area's to keep an eye out for?
    That's the only problem area that I've had. I think I'm going to get those sub connectors for my '86.
    Dec 2009
    St. louis MO
    She's still alive...almost. We are done with the bodywork and I'm just finishing up the blocking on the bumper covers hood and deck lid. It's been a slow project since I'm slow and a landscape construction contractor. I think we will be painting the car in a week or two. Lot's of pics will be coming if I can get a new computer that has some download space.
    Mount Washington, Ky
    Seems to be a lot of bad cowl areas showing up lately. Have you had the fenders off to see?
    Dec 2009
    St. louis MO
    Quote Originally Posted by ktp1598 View Post
    Yep, I'm good in the rust department. It just had a ton of dents like it was in a bizzaro hail storm.
    Dec 2009
    St. louis MO
    Default some pics
    Bear with me as I have a lot of pics to sort out. You saw some of the pics I have above from when I inquired about the car. I'll try to start from the beginning after my son and I picked it up from Dallas. I wish I had pics of it after being dragged through s snowstorm and salt for the first time in it's life probably. nice roof huh!
    Dec 2009
    St. louis MO
    Some more before stripping
    Dec 2009
    St. louis MO
    Some pic of the bodywork. We had to fix 47 dings/dents than some major surgery on the roof. We massaged it as much as possible but it was pretty beat up.
    Dec 2009
    St. louis MO
    Some more downloaded. Hopefully paint soon.
    FEP Power Member 86darkside's Avatar
    Jan 2009
    new jersey
    looks good
    FEP Super Member DRAGTOP89's Avatar
    dayton,maine
    love it
    putting together a little something special......stay tuned!
    92 notch-WIP
    87GT-S Trim,4:10s,AOD=12.70@107
    89vert-sold
    84SVO-WIP
    84 notch-aka-FREAKSHOW
    85GT shell-for sale
    78 Zephyr-WIP
    86 Capri RS-WIP
    Finally,the list of fox wants is complete!!!
    FEP Senior Member wannabe82's Avatar
    Jan 2009
    Savona,NY
    Lookin good, nice project ..
    Nice keep the pics coming! Yea we don't see any salt down here, but they do have a thing for laying sand on the road in these parts.
    Looking good so far! What color did you decide on?
    1985 5.0 Coupe - will eventually be hated by Ford purists
    Dec 2009
    St. louis MO
    I'm going with titanium frost and a black interior. I'm also thinking about switching to EFI if I can find a cheap donor car.
    Dec 2009
    St. louis MO
    Finally got some paint on the car. Now we need to cut and buff, fix some tiny blems and the small holes in the inner rocker area.
    Keith formerly STLPONDS
    '79 V8 coupe in the works!
    Dec 2009
    St. louis MO
    Few more and look at that roof from what we started with.
