Results 1 to 10 of 10
    Default 97 Expedition trans question
    Ok, so last week i bought my wife a 97 Expedition. super clean, super cheap, but has a trans issue. My buddy has a snap on scanner, so we went for a drive today. Only fault stored is for the trans temp sensor input. We watched the readings of the sensor, and it flares from 2 volts to 5 volts, and when it hits 5 volts, the overdrive light flashes.
    My question is, does anyone know where the trans temp sensor is located? I did a few serches and get nowhere. I ordered the sensor today, so i guess i will soon see, just curious what kind of a job im looking at.
    79 Capri RS
    341 rwhp,348 rwtq 11.20@127
    1939 Pontiac Deluxe 6. 73,xxx original miles. Barn find. Currently the secomd owner.
    2013 Focus ST
    2012 Taurus SEL
    1997 F350
    Dad has a 98 Expedition so I asked him if he knew, and he said it might be in the valve body, but he's never had the pan off so he's not 100% sure.
    Better than nothing I guess.
    MY GARAGE | SUPPORT THE 2.3
    1982 Mustang GT T-Top
    1993 Reef Blue LX 2.3 5spd
    thanks man
    79 Capri RS
    2013 Focus ST
    2012 Taurus SEL
    1997 F350
    Not sure whether you've got the 4R70W or the 4R100, but I know on the '97 4R70W, the
    transmission temp sensor is attached to the valve body. On the '98 and newer 4R70W,
    it's part of a one-piece connector assembly that connects all the internal solenoids.
    Regardless, you can access the sensor by dropping the pan.
    Cheers,
    Jeff Cook
    Cool. Thanks for the info. I called Ford today, to price out a factory sensor, and was told its only available purchased with the valve body, not by itself. So for kicks, I unplugged the bulkhead connector for the valve body, and it was full of green funk. I blasted it with electric contact cleaner, and let it sit, blew it out with compressed air, added some dielectric grease, and its MINT. No more harsh shifting, converter doesnt lock up and stall at lights, and the OD light no longer flashes. I did however, break the tab that locks the connector into place removing it, so i ordered a new harness connector and pigtail from Ford, 38 bucks. I figured it would be best anyways, new seals on the harness to keep the moisture out.
    Thanks for the response.
    79 Capri RS
    2013 Focus ST
    2012 Taurus SEL
    1997 F350
    FEP Power Member In2Fords's Avatar
    Mar 2009
    Honolulu, Hawaii
    hopefully that is all it was!! Im amazed at some of the things on craigslist that are just a simple fix
    Quote Originally Posted by In2Fords View Post
    I picked this thing up for 800 bucks. Eddie Bauer, new tires, ball joints, alternator, starter, ect. clean car, needed some tlc, and some maintenece. After changing all the fluids and a tune up, and a few comsetics, I should be into it for about 1200.
    79 Capri RS
    2013 Focus ST
    2012 Taurus SEL
    1997 F350
    Quote Originally Posted by varn82 View Post
    You got a freaking steal! Wait --- 4.6 or 5.4?
    Damn still a steal!
    Quote Originally Posted by 1982 niGhTmare View Post
    Damn still a steal!
    5.4. its got 140k on it, but runs like new
    79 Capri RS
    2013 Focus ST
    2012 Taurus SEL
    1997 F350
    Mar 2009
    Honolulu, Hawaii
    damn, you could rebuild the motor and trans and still be under blue book!
    I wish I could use my money for cars right now there are some deals, maybe when I win the lottery
