Results 1 to 17 of 17
    Default Bouncing steering wheel
    I am not talking an out of balance wheel shake, I am talking like a 110 pound stripper with 30 pound ass kind of shake. It goes up and down and all around, and no matter what I try it still shakes at highway speeds. The one thing I havent changed yet are the steering rack bushing, they are new but not offset. I guess since it has 95 Cobra spindles and balljoints the geometry is different that stock spindles, maybe casuing my ba-donka donk shake. Any other input would appreciated.
    PS: Sorry if its the wrong section, I'm a newb
    I have no help for you,
    but the description of the shake had me LMFAO!
    '85 ASC McLaren coupe
    EFI conversion
    Twisted Wedge heads, etc...
    13.2@105
    FEP Power Member MAD MIKE's Avatar
    Jan 2009
    San Leandro, Ca.
    http://vb.foureyedpride.com/forumdisplay.php?f=83
    Would be the ideal forum for suspension.
    I would advise NOT installing offset rack bushings on a factory K member.
    What other changes or modifications have you done?(suspension wise)
    How old are the front hubs? And are they torqued to spec?
    -Michael
    '79 Fairmont 5dr 'car guy safe' MM Tech Tips StopTech Brake Bias StopTech White Papers
    Quote Originally Posted by MAD MIKE View Post
    This car has had a lot of different suspensions on it, and wheels. The hubs were newish last I saw ( I knew the previous owner) when the spindles were swapped out. It did this on the stock stuff with mild lowering. I have even tightened down the steering rack supports and all. Currently the car has some adjustable struts one them and I dont know who makes them or how to adjust them ( havent really has time as winter sucks my left taint area). The suspension is heavily after market now except the stock lower control arms.
    The reason on NOT installing the rack bushing yet IS because there are mixed reveiws on doing so with a stock K member. Now since the 95 Cobra spindles change the geometry alot of folks say its necessary and some say "No way Jose". I havent made up my mind yet.
    Jan 2009
    San Leandro, Ca.
    Quote Originally Posted by SCHMUCKINGHAM View Post
    What kind of bushings are in the control arms? How old?
    What kind of BJs are you using? How old?
    What wheels tires are you using? etc etc.
    Lay it all out what is under the nose and how old it is.
    If you are using an unmodified stock Fox Chassis K member stick with non-offset R&P bushings. Only use the offset bushings if you have relocated the attachment points of the FLCAs on the K member.
    Before there was a '95 Cobra, or a '94 Mustang, there was the '93 Mustang Cobra R. This car came from the factory with what is known as SN95 Cobra brakes, or what can be purchased as the M-2300-K.
    There were no offset R&P bushings used. No need for them. Offsetting the rack on an unmodified K member will create issues.
    -Michael
    FEP Super Member 86capriASC's Avatar
    Jun 2008
    Edgerton,WI
    I'm running offset rack bushing on my stock K and no problems here.
    1986 ASCMclaren #108
    stock short block, Victor EFI, 75mm TB, 3.08's, Borla cat-back, slot style MAF conversion, Gt-40p heads, TFS1 cam, 80lb injectors, 69mm turbo, Moates Quaterhorse, E85. 501/584 @ the rear wheels
    Jan 2009
    San Leandro, Ca.
    Quote Originally Posted by 86capriASC View Post
    Why?
    -Michael
    Everything in the front end is new. 95 Cobra spindles and brakes, 03/04 Cobra wheels, Koni adjustables, Eibach Pro Kit, SN balljoints, tie rods are also new.
    They suggest running on offset rack bushing due to the 95 spindle moving the tie rod to a better geometry
    I have lowered two of my Capris and have offset rack bushings installed on both with the stock K member. It hasn't caused any problems for me either. MAD MIKE, just curious what problems you think it causes by doing this, cuz I can't think of ANY.
    Four Eyed Proud... Four Eyed FOREVER!!!
    '82 White on red Capri 255 c.i. C5 all original 112k miles
    '86 Black on gray Capri 5.0 5 spd all original 156k miles
    '86 Black on black Capri 5.0 5 spd fully restored mildly modded 7k miles
    '86 White on black Capri 5.0 C4 insanely modded
    So, if you grab the steering wheel and tug on it, does it flop around? May be just loose
    column bolts, especially if this is a tilt wheel.
    Cheers,
    Jeff Cook
    65 coupe, 289 auto, Pony interior ... '67 coupe 6-cyl 4-speed ... '68 Vert, Mexican block 307 4-speed...
    '71 Datsun 510 ... And a 1-of-328 Deep Blue Pearl 2003 Marauder 4.6 DOHC, J-Mod, 4.10s and Lidio tune
    Jun 2008
    Edgerton,WI
    Why?
    Lowered
    Ill try that next time I get in it, hopefully the whole steering column doesnt come with it
    FEP Senior Member yodaddyz82gt's Avatar
    Jul 2007
    Hollister, Calif
    mine was doin that "hop thing" at highway speeds over 65mph, but then i got new BJs installed, alignment new tires and problem solved. course i dont have a tilt steerin'
    82GTflossin
    Rebuilt 302,rebuilt 8.8 w 373s,JBAs, true dual exhaust flowmasters,T5 w/Hurst Short Shifter and a few more xtras..
    future upgrades: front/rear coilovers,15:1 rack,4bbl, rebuilding 89 susp with new bushings,85 carb/intake conv,jet glossy black new paint with custom graphics..
    Nov 2005
    Tampa, FL
    I have what I would call a "sensitive" steering wheel, where it'll move really easily from bumps or vibration. This thread: http://vb.foureyedpride.com/showthread.php?t=88197 may hold an interesting solution to the problem, though I have no idea where to get the part.
    1985 Mustang GT Convertible
    Jan 2009
    San Leandro, Ca.
    Quote Originally Posted by capri debris View Post
    The FLCA and tie-rod need to move together in parallel to prevent bump-steer. The factory does have an acceptable amount of bumpsteer designed into the suspension. You can improve on the slight bumpsteer that is in the factory design with a bumpsteer kit. This kit replaces the outer tie-rod with a spherical rod end, a long bolt and spacers. Using a bumpsteer gauge you can measure how much bumpsteer you have and reduce it by adding spacers between the steering knuckle, and the spherical rod end. Obviously it would be best to use a single spacer cut to the appropriate length to eliminate any movement that is in the spacer stack.
    If you change the rack location, which changes the inner tie rod location, you have taken the R&P out of alignment on the K member side. There is no need to do this with an unmodified K member.
    You will be creating more bumpsteer by relocating the R&P.
    The geometry between '78-'95 Fox Chassis is similar.
    With the introduction of the 4.6 in '96 the R&P had to be lowered to clear the engine. The '96-'04 spindles have a different steering arm on them to accommodate the change. The rack was lowered 1" so the steering knuckles had to be lowered 1". This is why on a stock Fox Chassis K member one should not use '96-'04 spindles. Where you need the outer tie-rod located is where the steering knuckle is. And there is no way to lower an R&P that much on a stock Fox K member without severe modification to the K member.
    -Michael
    Aug 2004
    Maryland
    You are certain it has 95 spindles? Check the MM site for comparison pics (http://www.maximummotorsports.com/co...tification.php) and an explanation why using the 96+ spindle on a pre-96 k-memeber car presentes many problems (http://www.maximummotorsports.com/co...le_warning.php) Finally, to correct some bumpsteer without the guage, try to get the bottom of the control arm and the steering arm to be parallel to each other (not the ground) at ride hight.
    For those who have off-set poly rack bushings, there are two issues: (i) the likely bumpsteer this causes and (ii) due to the radical off-center hole, the thin portion of the poly bushing moves in the mount causing rack-shift and of course, the attendent change in alignment settings. Stockers are better on a stock k-member.
    Quote Originally Posted by qtrracer View Post
    These are 95 Cobra spindles, not 96+. I took the steering wheel off and the entire column seems to move alot. Almost like the mounts are loose or something
