[QUOTE=1qk50;905337]Sweet!!!!! What steering wheel is that and what kind of door skins are those?
I have to agree you did a really excellent job in the interior or the car
~LES~
157 HP @ 4200 RPM
240 ft/lb @ 2400 RPM
Capri:
If i use all autometer gauges can i eliminate all the wires going to the stock gauge cluster?
84' notch
Here's mine with cobalt gauges. Still a rough mock up but you get the idea.
32v 86 coupe under construction
http://vb.foureyedpride.com/showthread.php?t=63991
+ Jalapeņo Red 1985 Mustang GT, 347 in^3, Canfield heads, 650DP, X-Celerator, & 1-5/8" LT's
+ Tremec 3550, D&D shifter, 3.73:1 gears, & TrueTrac differential
+ EVM watts & 3-link, Homemade LCA's, & Koni SA's
+ '00 Cobra R Brembos in front and SN95 Cobra rear brakes, R58 rims, & 275/40R17 Falkens
www.1985mustanggt.com
I don't actually have other pics that I have taken, but I found this pic on the net. They are Sparco Chrono road. I love them and they are a little bit different design then most seats you normally see.
http://www.sparcousa.com/pseats_street.asp?id=645
Tom
CAMMED & SLAMMED! For more build pics and updates: http://www.facebook.com/SINISBuilt
For being "BUILT not BOUGHT" I am still broke!
I thought they were Sparco's. What did you need besides the seats? Base, sliders, etc...
Thanks,
Vince
Well, I custom fabbed some adaptors to bolt them in. I didn't want them high in the car like some aftermarket seats tend to be so I skipped out on the sliders to keep them lower in the car.
Tom
Alright, been working on this for a couple days, here is what I have so far:
^^^ SWEET l got to do that to my 83 ^^^
1986 GT Convertible
1986 Mercury Capri RS (1st Project)
2007 F150 Fx4 - Daily Driver
2004 Harley Davidson Fat Boy
2004 F150 Lariat (Had)
2001 F150 Lariat (Had)
1997 F350 (Had)
1997 Explorer Limited (Had)
1993 Lincoln Mark VIII (Had)
1984 1/2 GT 350 - "The Begining" (Had)
Finished my gauge cluster upgrade and installed it. Made a harness so I could plug-n-play it. It's even using factory Ford connectors
And the finished product installed in the car. I kept the Autogage tach because it has a working shift light. Until I can get an RPM box that I can connect my mini-shift lite to, I'll keep it like it is:
did you have a mechanical drawing to lay out your new dash plate? eventually i want to do the same thing with either carbon fiber or aluminum and im curious if there is a mechanical drawing out there someplace. it will be much easier to mill out off a good drawing rather than the napkin sketch i will end up doing.
This is all I have right now...taken for unrelated purposes. I'll take some more after I paint it grey to match interior.
My major gripe using these as a daily driver is when the weather is crappy and rainy out, they start to fog up. Sorry design I guess.
Ed
"The Dude abides."
The trick is to run a little hobby filler putty inside the rings after you hole-saw it. That fills in all the porous areas where you cut the plastic. Just do that and sand it smooth.
I guess I'm glad I'm not the only one that has that issue. I'll trade that little nuisance for reliable instrumentation any day. If I get to in the next few weeks, I'll finish priming/painting that bezel and take some better pics.
Ed
"The Dude abides."
