Ok, it has automatic transmission (C3) and 3.08:1 axle, not the most economic set-up, but can't get better than 12mpg city, neither highway nor country side, same mileage whereever i drive, which is a bit too low for such an engine
That car had a better mileage before (well, in a way 'cause it was already ~16mpg) ... even with a dead PCV, vacuum hoses plugged at random, 0 initial timing, EGR left open, dist advance to intake vacuum (was running hot at idle when using timed-vacuum), dead dist cap, 30yo spark-plug wires, brittle spark-plugs (broke two only by sliding the socket on them), idle at 1400rpm in neutral ... every bit i did enhanced the way it ran except for mileage which got worse.
Status of the fuel hog :
- ~84.000 miles old
- vacuum hooses (new) reduced to minimal : distributor advance (timed vacuum), transmission modulator, brake booster, and vacuum gauge
- EGR blocked (thin aluminum plate with exhaust gasket material between valve and spacer) and disconnected (port plugged on carb)
- carb : rebuilt '77 Holley 5200 with new fuel filter, all vacuum ports blocked except timed-vacuum (distributor advance), electric choke installed but disabled (full open), new EGR to carb spacer
- initial timing set to 10deg
- PCV valve changed (hoose to oil separator a bit brittle but no leaks)
- almost new spark-plugs (NGK TR55 gapped to .040)
- new spark-plug wires
- new distributor cap, rotor, pick-up coil
- new ignition coil
- new air filter
- new thermostat : 180deg
- smog pump : removed (was dead), remaining check valve plugged
- cats : still one (close to exhaust manifold)
Carburetor setting :
- Primary
- idle jet : 60
- main jet : 140
- air corrector : 195
- emulsion tube : (hard to read) 95
- Secondary
- idle jet : 50
- main jet : 132
- emulsion tube : (hard to read too) 05
- Idle mixture screw set to 1-3/4, vacuum drops ~1-1/2
- accelerator pump set to middle hole
That's way leaner than factory carb (had way bigger main jets) but didn't enhanced mileage.
While tuning the carb, engine hot (normal) in Neutral, can't lower idle rpm better than 1200rpm (~800 in Drive) with 20-21inHg (15-16 in Drive).
Vacuum is quite stable while driving but fluctuates a bit at idle (1inHg variation either in Neutral or Drive).
Exhaust fumes doesn't smell rich at idle. Oil doesn't smell gas. Clean coolant.
There's some fresh gas smell when under a bit more than moderate acceleration (climbing a hill for ex.) but didn't notice any cloud at exhaust (a minor grey one at full throttle however) neither detected any fuel leak.
Have check all vacuum leak sources i could think of with WD40 (don't have better) ... from what i can tell, cat is not clogged (vacuum doesn't drop to 0 when accelerating), vacuum doesn't seem to show a sticky, leaking or burned valve nor bad valve guide, don't see blow-by at the intake to air-filter nor at the PCV valve, oil pressure was good last time i checked (factory gauge already dead, aftermarket gauge dead since but indicated correct pressure when i used it, waiting for another one) ...
There's some knocking when cold that i haven't located yet but seems to disapear when hot (maybe my ears are not sensitive enough).
When i changed the pick-up coil of the distributor, i noticed the springs were a bit rusty ... are they the same as on V8 dist ? Haven't checked the timing curve as i was alone last time my buddy lend me his timing-light ... but if they are the same, i can use the two clean V8 springs i have from a spare dist.
Any idea where to look now ?
