Ok, I have an original Holley carb for the Crimson Cat. It is from 1983, and I believe it is a 4180. If I am wrong with anything here, please correct me. All I know is what I think I remember or what I've been able to find with a couple quick searches. My '85 Capri has a 4180C, right? First of all, what are the differences? Is one better than the other? Is it just a couple of internal parts? And if so, are they interchangable?
Ok, next, I have an extra carb, which is pretty much a parts carb. I could get it back together, but the screws broke off for the throttle plates, so it would need some work. Now, I "think" this carb is a 4160. It does not have a secondary metering block, it has a metering plate. It has only one fuel inlet, but it is not at the same angle as the factory one, it just comes out the side of the front bowl at the top (driver side). I think that is pretty irrelevant, but just thought I'd mention it.
My question is, I have read and tried to understand the upgrades to the 4180C in the thread put together about that, but I guess I don't fully understand carbs, because the procedure is foggy to me. I'm wondering if the metering plate, or any other parts of this carb are interchangable with the 4180. If so, would it be to any advantage to use them? I need to rebuild the 4180, so I'm taking it apart either way. I just want to get the best parts back in it. How can I tell what size jets it has? The jets mount at a different angle on the two carbs. Does that matter? Can or should I swap them?
I guess what I'm looking for is, if any of you carb savvy guys are out there, what would you look for and do? By the way, this carb would most likely be going on the Crimson Cat, which is unmodified except for some missing emissions components, which will be going back on when I get them. Thanks.
