That is Dime_Story_Pony
I am not sure if in that pic if he had the wider rear tires or not. I know he swapped them and then had some major rubbing issue.
Just an FYI............................................... ..TireRack has 1 less set of Mach 1 wheels out of the 4 sets in Nevada.
I wonder who bought them.
Can't wait to see this!
1985 Mustang GT, owned since 1989
2000 Expedition XLT 219k miles
2011 Expedition XLT
Not trying to steal the thread by anymeans, just curious...
That coupe sure is a nice FE!
What tire size did he move up to and experience rubbing issues? I've run a 275/50 in the back on a 5.5" b.s. wheel (fox axles) and still had 3/4" - 1" between the tailpipes and about 3/4" between the tightest part of the wheelwell and the tire with no BFH clearancing or modifications whatsoever.
Think those Mach 1 wheels are a 5.72" b.s.? I could see a large 275/40-17 with that backspacing rubbing in the corners or with maximum axle articulation, etc. A 1/4" spacer (with good wheel studs) would solve that though!
Mark
1986 GT Hatchback (2R): 5spd, TFS FAC 170s, TFS Stage 2 Cam, Vortech SQ S-Trim, MM Suspension, SN95 5-lug conversion w/Fox 5-lug rear axles, 3.73's, 13" / 11.65" brakes, Moates QuarterHorse
'88 LX 5.0
'22 GT500
I'm pretty sure the Machs have the same back spacing as bullitts.
- CA car, 5.0 w/5 speed
- Cobra 17x8.5's + Modded Mach1 Chin Spoiler + 83-84 Hood & Scoop/85-86 "Blackout"+ FMS Mass Air Kit+ MM Clutch Cable & Quadrant + Fiore Cable Adjuster + MM SFC's+ Wild Rides "Battle Boxes" + Explorer Intake, Converted TB & Injectors, 70 mm Mass Air Meter + BBK Ceramic Shorties + 2.5" Bassani O/R X-Pipe & Cat-Back Exhaust w/ 3" Tips + 3L27 w/ Carbon Fiber Clutches(out of retirement) + Pistol Grip Shifter + 99-04 GT Front/00 Cobra Rear Disc Brakes
Mach 1's without a doubt!
'83 GT - 545 - C6 - 3.90 - it's alive!
'85 Silver Metallic GT - http://vb.foureyedpride.com/showthread.php?t=80575
My wheels arrived on Wednesday. Time to set the two toned coupe aside for a bit and do the 5 lug conversion on the T-top coupe.
Sorry for the delay everybody. I was waiting till I decided on tires before I posted pictures. My five lug conversion will be done durring my holidays so I can concentrate just on the car. Well here you go.
I am soooo jealous... nice choice!
I'll trade yah!
I went with Cooper Zeon 2XS 255/40/17. So I won't have any rubbing issues in the front. Plus the wider tread will look great!
chrome ponies are the key.
82 ford fairmont futura
quicktime turbosystems 70mm turbo
10.67@128.38
Here is my parts List of the other goodies going on the car.
STD-5558200 Steeda Sport Springs, 79-04 Mustang V8
TOK-HB3026 Tokico Strut - 87-93 Mustang
TOK-HE3608 Tokico Shock - 87-93 Mustang
STD-5554420 Steeda Steel Lower control arms, 79-98 Mustang
STD-5554094 Steeda HD Upper Control arms w/ bushings, 79-04
Mustang 5 lug complete conversion kit, front and rear
used 87+ spindles
Front Calipers
HWK-HB263F650 Hawk Ferro Carbon Pads, 87-93 Mustang 5.0 front ,HD street
Raybestos Rear shoes
EAR-28B040 Earls Stainless Brake Lines - 89-93 Mustang, 2 front, 1 rear line.
WIL-2900633 Wilwood Hi-temp brake fluid, 570 degree dry boiling point
MMM-CC7989 Maximum Motorsports Camber/Caster Plates, 79-89 Mustang
Rack and Pinion, 15:1, 87-93 Mustang
TRW-ES2150R TRW Outer Tie Rods 87-93 Mustang
ENE-410103 Energy Rack Bushings 85-95 Mustang
I'm drooling!!
Is there a part number on the front rotors? Just wondering what vehicle they are originally for.
I am not sure. It is a complete kit with front rotors and rear drums and axles with all the seals and bearings. This kit might be the same as the one from LMR.
