Results 1 to 4 of 4
    FEP Member cbratch67's Avatar
    Feb 2009
    From TX, stuck in Cincinnati
    Default Decoding for 83 RS Turbo Please
    Date 08/83
    VIN:1MEBP79WXDF624880
    EXTERIOR PAINT CODE:35
    DSO:53
    BODY:61D
    VR:BLANK
    MLDG:BLANK
    INT. TRIM: HB K
    AC:7
    R: D
    S:R
    AX:2
    TR:KKHH
    Buck Tag is missing, right? Can you please list all the options the car has. Thanks.
    Also, don't know if it's a typo on your part or if they're printed like that on the VC Label but starting with the "K" at the end of the INT. TRIM, all of those codes should be shifted one column to the right, i.e. A/C = K, R = 7, S = D, AX = 2, and TR = 2KKHH.
    VIN
    1ME = USA, Mercury
    B = manual seatbelts, no airbags
    P = passenger car
    79 = Capri three-door hatchback
    W = turbocharged 2.3L engine
    X = VIN check digit
    D = 1983 model year
    F = Dearborn Assembly (DAP)
    624880 = 24,880th 1983 Capri assigned a VIN at DAP
    VC Label
    DATE - 08/83 = August 1983 scheduled build date
    EXTERIOR PAINT CODE -35 = Light Academy Blue Metallic
    DSO - 53 = Oakland district sales office
    BODY - 61D = Capri three-door hatchback
    VR - [blank] = no convertible roof
    MLDG - [blank] = no special-colored bodyside moulding
    INT. TRIM - HB = high-back, cloth "Sport Performance" seating (H), Academy Blue interior color (B)
    A/C - K = bodyside paint stripe color code for Light Academy Blue Metallic exterior paint
    R - 7 = AM/FM cassette stereo radio
    S - D = T-roof
    AX - R = 3.45:1 axle ratio w/ Traction-Lok differential
    TR - 2 = T-5 transmission
    KK = E0BZ-5310-R front coil springs
    HH = D9BZ-5560-M rear coil springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Feb 2009
    Hey Mick, thanks for the info. Did you get the pics? Yeah the letters are actually under the left side of the columns and should probably be shifted one space to the right.
    Thanks,
    Chris
    Yup, got the pictures. I think I have more to give you from when the previous owner posted them...
