Results 1 to 7 of 7
    FEP Power Member COLD's Avatar
    Feb 2009
    Beaver Dam,Ky
    Default Need Decode on 84 Capri,please.
    Her are the vin and buck tag. The vc label is there,but I can only read the last few digits.
    vin# 1MEBP79M6EF617490
    buck tag
    Capri
    617490 61D M TR 0289
    1E DF ST
    AC 06 HB
    CRS PW MBW 02
    EL-A 06 2 3 4NLR
    vc(what I can read of it)
    DSO 32
    12Bor 128 D Z 25??
    Thanks in advance!
    On the VC Label, is the 12B/128 beneath INT. TRIM or is the 12 beneath A/C and the 8 beneath R?
    Does the car have...
    light in glovebox, front ashtray, and underhood?
    interval windshield wipers?
    "Sport" seats?
    AM, AM/FM stereo, AM/FM stereo w/ cassette, or radio delete?
    premium sound system ("AMP PULL" knob under dash)?
    turbine wheel covers or cast aluminum metric (TRX) wheels?
    front license plate bracket?
    Feb 2009
    Beaver Dam,Ky
    Well it's not staying the way I put it in when I post it?? The dividing line between int trim and R is above the 1 and the dividing line between R and S is above the 8 or B. If that makes since
    light in glovebox, front ashtray, and underhood? YES
    interval windshield wipers?<YES
    "Sport" seats? SEATS ARE MISSING
    AM, AM/FM stereo, AM/FM stereo w/ cassette, or radio delete? MISSING
    premium sound system ("AMP PULL" knob under dash)?YES
    turbine wheel covers or cast aluminum metric (TRX) wheels? MISSING
    front license plate bracket? NO
    Thanks!
    OK, does the VC Label go something like this?....
    VIN:
    TYPE:
    EXTERIOR PAINT COLORS ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​ ‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​ ‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​ ‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​ ‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎DSO
    BODY| VR | MLDG |INT.TRIM|A/C| R | S | AX | TR
     ​​​‎ ​​​‎  ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​ ‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎  ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎  ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎  ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎  ​​​‎ ​​​‎ ​​​‎​​‎​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎1  ​​​‎ ​​​‎ ​​​‎ ​​​‎8 ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​ ‎D ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎ ​​​‎Z ​​​‎ ​ ​​‎ ​​​‎ ​​​​​‎2SS??
    Feb 2009
    Beaver Dam,Ky
    VIN:
    TYPE:
    Kinda. If the numbers were moved down.Maybe it will stay the way I typed it?
    | R| S | AX | TR
    128 D Z 2SS
    Well, I can tell you the D belongs under S, the Z belongs under AX, and the 2SS__ belongs under TR. There is only supposed to be one number under R, so I'm trying to figure out if it's the 2 or the 8 (1 is not a valid radio code). And 1 or 2 could be under A/C (which is between INT. TRIM and R). There should be an _A under INT. TRIM but no numbers.
    VIN
    1ME = USA, Mercury
    B = manual seatbelts, no airbags
    P = passenger car
    79 = Capri three-door hatchback
    M = 5.0L V-8 engine
    6 = VIN check digit
    E = 1984 model year
    F = Dearborn Assembly (DAP)
    617490 = 17,490th '84 Capri assigned a VIN at DAP
    Buck Tag
    CAPRI = model line
    61D = Capri three-door hatchback
    M = 5.0L V-8 engine
    TR = T-roof
    0289
    1E = Silver Metallic exterior paint color
    DF
    ST
    AC = factory air conditioning
    06
    HB = rear defrost
    CRS = RS option/trim level
    PW = power windows
    MBW = T-5 transmission
    02 = no hood scoop
    EL
    -A = Charcoal interior trim color
    06
    2
    3
    4
    NLR
    VC Label
    EXTERIOR PAINT COLORS - 1E = Silver Metallic
    DSO - 32 = Cincinnati district sales office
    BODY - 61D = Capri three-door hatchback
    VR - [blank] = no convertible roof
    MLDG -
    INT TRIM - _A = _____ bucket seats, Charcoal interior trim color (A)
    A/C - 1 or 2 = tape stripe code for Silver Metallic exterior paint
    R - 2 or 8 = radio delete (2) or AM/FM stereo w/ auto-reverse cassette (8)
    S - D = T-roof
    AX - Z = 3.08:1 axle ratio w/ Traction-Lok differential
    TR - 2 = T-5 transmission
    SS = E3BZ-5310-H front coil springs
    __ = __BZ-5560-_ rear coil springs
    Feb 2009
    Beaver Dam,Ky
    I wish the label wasn't in as bad shape as it is.Thanks for going through the trouble!
