Some people believe that all transmission filters are backflushed clean every time the vehicle is turned off. This is a major misconception. Three-quarters of all transmission filters today are not a simple screen, they are made of felt. A felt filter CANNOT be backflushed. Felt holds dirt particles within tiny pores in the felt. It will not wash out or flush out. If a felt filter becomes clogged it must be replaced. Clogged filters restrict fluid flow, which lowers pressure to clutches and bands. This can cause slippage and eventual burnout of the transmission.
There have been an increasing number of instances surfacing recently regarding transmission failures shortly after an evacuation service, without filter removal. At the time of a fluid evacuation service, there is no way to know the condition of the filter and how clogged it may be. The filters job is to collect and hold contaminants, (dirt, metal filings, friction particles, etc.), and prevent these particles from causing malfunction in such components as electronic force motors and solenoids. Today's transmissions are far more susceptible to malfunctions caused by fine dirt contamination. Without servicing the filter, there is no way to know if the filter is clean of debris or nearing capacity. If the filter is nearing capacity, transmission failure may not be far off. This is also a sign that there may be other internal problems in the transmission. Recognizing these warning signs could eliminate major service later.
Most of the transmission failures after an evacuation service have occurred primarily on relatively high mileage transmissions that have not been serviced in some time. One reason for this is that the sludge and dirt buildup within the transmission will not completely be removed during the service. When the new fluid (which has detergent properties) is placed in the transmission, over days and weeks, the internal components begin to wash the insides of the transmission.
This sludge does finally work loose and settles in the transmission filter, clogging it up even further than it may have been before service. In these extreme cases, where service has not been performed in some time, changing the filter may not completely fix the problem. Some mechanics recommend a second service a few weeks after the first, replacing the filter again, which may be partially clogged due to the cleaning process in the transmission.
