I am in the process of putting a 302 and a T5 in my '85 Mustang coupe that originally had a 4 cylinder and an automatic.
I am running a Duraspark with the GM HEI module, and bought a parts store coil. I have two questions about the coil:
1. Instead of studs with nuts for the electrical connections, it has these funny looking studs with hats (?) and I have no idea how to make the connections from the ignition module to the coil. Any ideas? Does anyone even know what I am talking about?
2. My Ford Racing ignition wire set came with two coil wires - a short one with a male and female end, and a long one with two female ends. I want to put to coil on the fender well, but the coil wire that I need to use is too short. Do I mount the coil on the intake? Can I get a longer correct coil wire somewhere? Can I swap the male end to the longer wire?
Is it feasible to use the 4 cylinder coil that was on the fender well when I bought the car? It would hook right up, but Ihave my doubts as to whether it would put out enough juice for the 302.
Thanks in advance for the help guys - I know there are a lot of questions here...
