I rerouted all the wires up into the fender and now the passenger side low beam goes off when i hit the high beams. it works on low and the driver's side stays on.What is going on?
1985 Mustang GT-2R,1986 5.0,Tremec 3550,Spec Clutch,Pro 5.0 shifter,Edelbrock Performer RPM,Holley 650 Equal Length Shorties,off road h-pipe,Flowmasters, MSD 6AL,8.8 rear,Pony's.
Past Rides
1985 Canadian Cobra 5.0 5spd RIP
1982 GT Black T-top-please come home!
Hauler
2000 F-350 XLT CC 7.3 Powerstroke Power!
something is wrong and not wired right. My car doesnt do that
86 w/87 motor,full cage, gutted interior,5 lug, H&R front springs, SVO A arms, jeggster subframe connectors, driveshaft loop, 2007 mustang bullitts, 25th anniversary dash, 87+ qrtrs....
96 honda civic 4 door
01 suzuki sv650s v twin crotchrocket
see told you, the wiring is messed up
i also put in a new turn/multi switch too.I don't know if it did this before.I'll pull the plugs and see if that helps.
Past Rides
Hauler
Yep Hirsche is on the problem with the wiring. I bet it worked before you touched it an messed it all up?
Hey come on now,if I mess things up I mess them up good-if this was my fault the lights wouldn't work at all!
Past Rides
Hauler
