Results 1 to 8 of 8
    FEP Member hirsche23's Avatar
    Feb 2009
    Innisfail,Alberta,Canada
    Default Headlight problem
    I rerouted all the wires up into the fender and now the passenger side low beam goes off when i hit the high beams. it works on low and the driver's side stays on.What is going on?
    1985 Mustang GT-2R,1986 5.0,Tremec 3550,Spec Clutch,Pro 5.0 shifter,Edelbrock Performer RPM,Holley 650 Equal Length Shorties,off road h-pipe,Flowmasters, MSD 6AL,8.8 rear,Pony's.
    Past Rides
    1985 Canadian Cobra 5.0 5spd RIP
    1982 GT Black T-top-please come home!
    Hauler
    2000 F-350 XLT CC 7.3 Powerstroke Power!
    FEP Super Member 83GTRAG's Avatar
    York, PA
    something is wrong and not wired right. My car doesnt do that
    Quote Originally Posted by hirsche23 View Post
    i had this happen too. it ended up being something in the high beam low beam switch.but it might just be a lose wire that shorts when the high beam draws current. i would recheck that everything is plug in good and make sure the connection on the headlights isnt dirty
    86 w/87 motor,full cage, gutted interior,5 lug, H&R front springs, SVO A arms, jeggster subframe connectors, driveshaft loop, 2007 mustang bullitts, 25th anniversary dash, 87+ qrtrs....
    96 honda civic 4 door
    01 suzuki sv650s v twin crotchrocket
    York, PA
    see told you, the wiring is messed up
    Feb 2009
    i also put in a new turn/multi switch too.I don't know if it did this before.I'll pull the plugs and see if that helps.
    Past Rides
    Hauler
    York, PA
    Yep Hirsche is on the problem with the wiring. I bet it worked before you touched it an messed it all up?
    Feb 2009
    Hey come on now,if I mess things up I mess them up good-if this was my fault the lights wouldn't work at all!
    Past Rides
    Hauler
    York, PA
    luv ya man!
