Results 1 to 19 of 19
    Anthony
    Guest
    Get a flaming river rack. Can be found cheap on eBay. You need new tierod ends too.
    Double humps were 86 and up. Ford racing sells new ones.
    Jan 2003
    lansing, mi
    as far as the trans cross member goes, you need one off a 86-93 v8 stang. aod sits back furter in the chassis, manual sits more forward. aod cross members will work with the t5 trans from my experiences.
    cale
    FEP Member darkwriter77's Avatar
    Sep 2008
    Apache Junction, AZ
    Summit Racing sells a complete manual rack and pinion kit for a decent price that comes with a rack and new outer tie rod ends (the ones from your power rack will not fit). However, you will also need to buy a new steering shaft, as well, as the power and manual racks use different shafts. DO NOT buy the Flaming River steering shaft. Either find a Ford shaft from a junkyard/eBay/Craigslist, or order a Maximum Motorsports manual steering shaft.
    Double-hump crossmembers, as stated, can be found on any '86-'93 5.0 Mustang.
    1986 GMC S-15 ext. cab 2.8 - DAILY BEATER.
    1989 Mustang LX 5.0 notch - T-5, 4.10, alum. DS, KC clutch, Pro 5.0 shifter, O/R-X and Violator cat-back, A/C delete - WEEKEND TOY.
    Anthony
    Guest
    Love to hear your reasoning on why not to use the flaming river shaft. I need some amusement today. Flaming river also sells the a nuckle to adapt the manual rack to the factory steering shaft. It retains the rag joint.
    Feb 2009
    Western PA
    Quote Originally Posted by darkwriter77 View Post
    Just curious why you don't like the flaming river shaft?
    Yes, I also would like to know. For me it worked well.
    1986 GT
    347 n/a 11:1 comp
    AOD Lentech
    4.56 gears
    11.27@119.1
    FEP Power Member Peganit2's Avatar
    Davison, Mi
    I'm curious too. I thought their ad stated they were an OEM supplier?
    A real cheap way to get a manual rack is to remove the power steering pump, lines and the internal valving from your ps rack, and plug the holes with pipe plugs or set screws, I forget the threads. It works fine, though it isn't as clean looking as a dedicated manual rack.
    Current list o' cars
    87 hatch california car 94 SHO Taurus DD 96 Aerostar FH 77 HighBoy with a BBF
    Memorable cars from my past
    69 stang sports roof 302 GT RARE! 63 XL Galaxie loaded 75 Torino with a BBF 80 Capri coupe 82 stang hatch Turbo conversion car 82 Escort with a 2.3 85 'stang coupe with a 4.6L 4V Cobra motor 85 LTD with a 302 67 'stang coupe roller 61 Starliner Galaxie with a 428 SCJ 72 'stang sport roof
    Sep 2008
    Apache Junction, AZ
    Just heard a lot of gripes from folks on here and other sites about how the Flaming River shaft is made kind of flimsy and only has a couple of stop screws holding the thing in place. Haven't heard any horror stories yet of an actual steering shaft failure, but I'd rather not suggest it to someone and have them be the first to experience that.
    FEP Super Member 93-331-29PSI's Avatar
    Dec 2005
    Chesapeake VA
    I got a Maximum Motorsports steering shaft. Fits well, but haven't driven with it yet.
    83 GT Turbo
    84 GT Turbo
    84 RS Turbo (Rotter/Parts Car)
    86 Capri (Project Green Bean)
    FEP Power Member wman24's Avatar
    Mar 2009
    Maple Shade, NJ
    How are the manual racks as far as arm power needed too turn?
    the summit rack set up comes with the steering shaft. i just installed their complete kit. 330 bucks for everything. manual rack, tierod assemblies, steering shaft, urethane bushings for the k-member mounts, and all hardware. real top quality stuff for short money. id recomend the standard ratio, it steers like i have power steering, and i dont. i can post some pictures of it if you want.
    79 Capri RS
    341 rwhp,348 rwtq 11.20@127
    1939 Pontiac Deluxe 6. 73,xxx original miles. Barn find. Currently the secomd owner.
    2013 Focus ST
    2012 Taurus SEL
    1997 F350
    Sep 2008
    Apache Junction, AZ
    Doesn't the Summit Kit come with a Flaming River steering shaft?
    it comes as a complete kit from "unisteer". all parts are matched, and fit nice.
    79 Capri RS
    2013 Focus ST
    2012 Taurus SEL
    1997 F350
    Davison, Mi
    Quote Originally Posted by wman24 View Post
    If you're a girl you'll complain.
    I just had to say that.
    But a real man don't even complain about a converted ps rack.
    Mar 2009
    Maple Shade, NJ
    Guess that means I should be able too use one hand
    with a standard ratio rack, i have no issues whatsoever. my wife drives the car regularly, and doesnt have an issue with it. if you are at a dead stop, with the brakes applied, you know there is no power assist. other than that, one of the best alterations to my car i did. i love the way it drives on the highway, nice road feel. pretty cool.
    79 Capri RS
    2013 Focus ST
    2012 Taurus SEL
    1997 F350
    Feb 2009
    Western PA
    I think the manual rack is 4 turns lock to lock (verses 3 for the power rack)
    So you trade slower steering response for less turning effort.
    Feb 2009
    Western PA
    Quote Originally Posted by varn82 View Post
    I have to say that is mighty tempting. My PS has no feedback.
    i went with it because my pump was leaking, my lines were dry rotted, and my rack was leaking. oh yeah, and both outer tierods had play in them. so it cost me the same to go with a new manual vs reman'd pump and rack, and some lines. plus it freed up some space under the hood.
    79 Capri RS
    2013 Focus ST
    2012 Taurus SEL
    1997 F350
