Results 1 to 17 of 17
    Neither here nor there
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
    Default How To: Replace a broken mirror in your sunvisor
    Ok, so you have a busted mirror and you want to replace it.
    First you use a fork screwdriver under these 3 locations and gently pry up.
    This is a view from a junk visor I have, so that is why this one is vinyl. Just wanted to show the tabs. The middle tab on this visor did break off, but once the other 2 side are pressed down it sat down fine.
    **You will need to remove the mirror from a junk visor or possibly have one cut at the hardware store using the dimensions from the old one**
    As this point, I do not have any broken tabs on this cloth one, gently lift up on the mirror frame and slide out the busted mirror.
    NOTE: Be careful sliding it out as to not slice the fabric or vinyl with the edge of the mirror or any broken fragments.
    Insert the new mirror in the same fashion, again using caution.
    Snap down the tabs back into the holes and your done!!
    If for some reason you have a broken tab and it doesn't sit down flush, you will have to put some epoxy on it and a weight to hold it down til it dries.
    So this set is now repaired.
    Cool info. Never knew they came apart like that.
    MY GARAGE | SUPPORT THE 2.3
    1982 Mustang GT T-Top
    1993 Reef Blue LX 2.3 5spd
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
    Well honestly I didn't either until I spoke with LxFiveo and he told me about it so of course I had to try. Now we all know. So, thanks to him as well for the info!
    FEP Super Member K PONY's Avatar
    Oct 2006
    Oakville, Ontario
    [QUOTE
    [/QUOTE]
    Looks good Jeff... now give the material a JeffClean and you will be all set.
    Now if only somebody could show how to take the mirror and put it on a reproduction visor which has no mirror.
    Quote Originally Posted by negusm View Post
    Glue?
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
    Quote Originally Posted by K PONY View Post
    [QUOTE
    Looks good Jeff... now give the material a JeffClean and you will be all set.[/QUOTE]
    Actually the lighting made them look worse then they are, they are actually REALLY nice. But your right I bet a little jeffclean would go a long way.
    you might want to add "when you put the weight on it, make sure not to break the mirror you just installed" ha ha
    No Longer a 4I Owner
    But Have way too much 4I stuff Collecting Dust.
    Quote Originally Posted by 1982 niGhTmare View Post
    Glue?
    That won't make it look like it's pulled into the fabric. You can use glue but you need to get it mounted into the inner board somehow so it pulls down the fabric.
    -Mike
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
    -Mike
    I would put the glue where the stub broke off as it would reattach to the piece that is still down inside.
    And yes, don't break the mirror with the weight...LOL
    Quote Originally Posted by Capriman86 View Post
    Yeah, on the original...I was talking a repro where there is no hole. I guess you'd have to put holes in the fabric and in the visor's inner board.
    -Mike
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
    oh oh, duh, never mind.
    sorry getting late..lol
    maybe I should flip over my junk one and see what I can do with the other side..hmmm
    St. Louis, MO.
    That is great info!!!! Thanks for sharing!
    Scotty
    Past Pony's.....
    FEP Power Member bluesfannoz's Avatar
    Aug 2007
    Lawrence, Ks
    One of the situations where this photobucket crap has come back to bite us! Would love to see the original pictures Jeff - CapriMan86!
    Steve
    "Taillights in Your Face Jack? You've just been Dominated!"
    # Link to Facebook Dominator Mustang Fans # # Link to Facebook Predator Mustang Fans #
    # Link to Facebook Twister Mustang Fans #
    Current Stangs: Stangless
    Previously owned:
    84 Black GT, 85 Black T-Top Dominator GT # Link to Restoration Thread # 85 Dominator GT RIP 1995, 85 Predator GT, 83 Dominator GT, 82 Mustang GT
    When i took mine off (79 oem ps non lighted, no cover) it was hot melt glued to visor.
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
    Quote Originally Posted by bluesfannoz View Post
    Little late to the party, trying to catch up since I've kinda been MIA, just changed the hosting, let me know if you can't see them now
