Ok, so you have a busted mirror and you want to replace it.
First you use a fork screwdriver under these 3 locations and gently pry up.
This is a view from a junk visor I have, so that is why this one is vinyl. Just wanted to show the tabs. The middle tab on this visor did break off, but once the other 2 side are pressed down it sat down fine.
**You will need to remove the mirror from a junk visor or possibly have one cut at the hardware store using the dimensions from the old one**
As this point, I do not have any broken tabs on this cloth one, gently lift up on the mirror frame and slide out the busted mirror.
NOTE: Be careful sliding it out as to not slice the fabric or vinyl with the edge of the mirror or any broken fragments.
Insert the new mirror in the same fashion, again using caution.
Snap down the tabs back into the holes and your done!!
If for some reason you have a broken tab and it doesn't sit down flush, you will have to put some epoxy on it and a weight to hold it down til it dries.
So this set is now repaired.
