86 mustang gt First, I have had the battery checked and it is fine. What is happening is this. With the door open and the key inserted in the ignition switch, you do hear the door buzzer go off. As soon as you turn the key out of the locked position, absolutely nothing. If you remove the key and insert it again, still nothing. Could this be the ignition switch or a relay?
New parts alternator 65amp ,starter,solenoid.
