Results 1 to 8 of 8
    FEP Member 83glxdroptop's Avatar
    Feb 2008
    Southeast Los Angeles, CA
    Default Tail Light Interchangeablity
    Can anyone tell me if the '79 to '82 tail lights will bolt up to the '83 to '86 body? I read somewhere that the mounting points were different. Someone suggested that I put '79 tail lights on my vert' since I already had a '79 front end (was already like that when I bought it). I kind of like the idea but wanted to be sure of the placement.
    Parts Destroyer gdniel's Avatar
    Aug 2003
    St. Augustine, Florida 32092
    The tailigt panels are completely different between the 79-82, and 83-93 cars. While you could get the older lights to bolt up on the newer panel ( may require cutting), they will never seal as the newer lights use 3 seperate seals across the width of the light, the older ones did not.
    Fun is fun, and done is done!
    The wiring is different as well.
    Aug 2003
    I forgot to add that.
    Feb 2008
    I guess I could always get 1) the '83 front or 2) get a 79 rear cover.
    Aug 2003
    An 83 nose would be very easy to swap on to your vert.
    Feb 2008
    A front end swap would also mean hunting down an '83 hood as well. I read some threads on here regarding special aftermarket convertibles that were produced from '79 to '82. Now if were to see one of those it would be a one in a million shot. Clean verts regardless of engine year combo are VERY rare. I want something different.
    Aug 2003
    Changing a tailight panel is a whole lot more work than getting a hood and bumper cover installed and painted.
