Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
  1. #26
    FEP Senior Member David Claflin's Avatar
    Oct 2008
    Redneck Riviera, Fort Walton Beach Florida
    Most of us cougar/bird guys were using those springs in the rear. It dropped it pretty good. Maybe too much for me, some were using adjustable rear lower cont arms to get the ride height dialed in for them.
    I was just looking at the moog site and what I've found for spring numbers at rock auto and the rear spring for an LTD LX is the same as what they show for the rear of an 85GT of the same year.
    1990 Red LX, GT40 heads, CSE cam, Ported explorer intakes, 1 3/4 long accufabs, 3" exhaust, T5, 4.30, lightened up some, 7.4X@91, working to get it lower.
    1985 LTD LX, Mach1 brakes, 17" Mopar police car wheels. 7.86@86MPH with 302, 3640 pounds with 1/4 tank of gas and me in it. 347 build in progress
    1986 FHP coupe, yet another work in progress
  2. #27
    FEP Member ratio411's Avatar
    Apr 2011
    Pensacola, Florida
    That wasn't the 'Moog site'... It was an "independent Moog parts dealer".
    Here is the Federal-Mogul tech site:
    http://www.fme-cat.com/
  3. #28
    FEP Power Member LTDScott's Avatar
    Oct 2004
    San Diego, CA
    Interesting that this topic has come back to life. I'd like to go with stiffer rear springs on my car but most Mustang springs are too low. Might have to check out the Moog catalog to see what options are out there.
    85 Ford LTD LX: Four eyes and Four doors
    EFI swap, AFR 165 heads, 5-speed conversion, Cobra brakes, etc.
  4. #29
    Oct 2008
    Quote Originally Posted by LTDScott View Post
    The coils on the wagon were .589, while the LTD LX were .620
    The 823 are substantially stouter then the 821 that come stock on the LX. Rock auto lists the 823, 821 and the 8597 as replacementss for the rear of an 86 LTD. I imagine the wagon would normally have the 823's but the coil diameter is too small on mine.
    For what it's worth the H+R race are close to the standard LTD LX springs, in rate from what I can tell, they are 11.5 free standing whereas the LTD LX are 12.29.
  5. #30
    Oct 2008
    Quote Originally Posted by ratio411 View Post
    True, but that information is still correct as far as I can tell.
  6. #31
    Oddly enough I have found that Amazon.com has the most complete "what else does this part fit" listing for these springs. I pulled a set of Thunderbird V8 springs out of the junk yard for use on the Lemons Futura after a long search of the internet. The Moog 8599 spring used in the back of the Fairmont wagons is also a stock Tbird part, and seems like the stiffest of the factory options.
    Which brings me to my next question: Anyone know the stock ride height? Either the factory spec, and where its measured, or just with a tape measure to some standard point with stock springs and tires. I don't need to be super exact, but my car was lowered with a torch before I got it and I want to know where it sits now in relation to that.
    Woody
  7. #32
    Oct 2004
    San Diego, CA
    Huh, good to know.
  8. #33
    Oct 2008
    I measured the LTD LX rear springs, they were .620 coil diameter. The LTD wagon rear springs were .589. According to rockauto.com there are a couple different springs for these cars. The 8823 is the stiffest available, and they are supposed to be in the wagons, not sure why mine doesn't have them, but it gives me options to upgrade depending how it behaves at the track.
  9. #34
    Forget all that. Go to www.coilsprings.com call them. Dont emIl or you will never hear from them. Tell them what you have exactly what height difference you want from stock and how much of a springrate increase you want over stock. They will wind you a custom made set to youe specs. When i had them do the springs for my tempo (o.ly stock replacements are available and i wanted it lowered and stiffer) i got a 2" drop in front 1.5 in back and a 25% rate increase all around. Spent about 300 shipped. 6 weeks later i got them and they lowered the car exactly what i said and they were stiff enoigh to not bottom out my stock struts but still ride good.
    2013 Focus ST3 2.0 turbo 6 speed
    85 LTD, 90k miles, 3.8/c5,For sale... Or restomod if it doesn't sell
    87 Conquest TSI widebody 2.6 Turbo/5speed, also maybe for sale
    94 Tempo 3.0v6/5speed 92 GLS clone project
    90 gmc sierra 2wd short box. 73k showroom condition, fender flares, 31" BFG All terrain. 350ci 4.10 gear
  10. #35
    Quote Originally Posted by Chrome_Rush View Post
    Bumping an old thread!
    I may talk to these guys. I would like a higher spring rate than what the LTD LX had come with (275). Maybe a 300# spring.
  11. #36
    Oct 2008
    Quote Originally Posted by Marz View Post
    Did you talk to them? This wagon I picked up has mustang lowering springs, and air shocks in the back. Moog has discontinued the CC823, so I need something to use in this heap.
    Found these on Ebay, but it lists them as T-bird/sedan
    https://www.ebay.com/itm/Moog-Coil-S...Fas6wU&vxp=mtr
  12. #37
    Grand Rapids, MI
    Rockauto lists a Delco p/n 45H2082 for the wagons that looks similar to the specs you listed for the Moog 8599. In fact it is the only rear wagon spring they list.
    https://www.rockauto.com/en/moreinfo...131590&jsn=473
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '95 Saturn SW2
    '85 Ford LTD Squire
  13. #38
    Oct 2008
    Weird, I initially only checked 84 LTD, and it listed one option, and that one was out of stock. I ordered a set through JC Whitney via the link I posted earlier.
  14. #39
    Feb 2011
    Minneapolis, MN
    Steer clear of Moog CC (Cargo Coils)....your car will be lifted more than stock...aka "four by four mode". I don't care what the specs say. Been there done that many many times on a 1984 LX 5.0, 1989 Taurus, 1985 Nova, and they wouldn't even fit on my 1963 Falcon, and on my 1989 Bronco II I had so much positive camber it was unsafe, and it was awful looking. (Yes, I used to work at CARQUEST which was Moog suspension). Your better off going with Eibach, BBK, FMS, or others and lower the car slightly (0" to 1/2" if you want stock looking) in the process.
    Terry
    78 Fairmont Sedan V8 - Factory black interior, factory A/C, No longer a SHO project, t/c 8.8 diff w/ 3.73LS
    85 LTD LX - Black, 5.0L CFI, crank windows
    93 Mustang LX 5.0L notch - original owner, 20k original miles
    17 F250 - My RV Trailer, projects, and car hauler vehicle
  15. #40
    Oct 2008
    Quote Originally Posted by SHOmont View Post
    Thanks, already got them, first thing I did before putting them in was cut a coil off...LOL!
  16. #41
    On my 79 Zephyr wagon with a small block and A/C, I would like to have a lowered stance along with excellent handling. I am installing an AJE front K-member, Mustang GT rack and spindles.
    So, here are my questions:
    1) Which front and rear coil springs will give me a lowered (2" all around) stance?
    2) If I decide to go with coil-overs what front spring rate do you recommend?
    3) What brand/source is a good low cost coil over?
    4) With a lowered stance what type of rack bushing do I need, off-set or standard?
  17. #42
    Oct 2008
    Maximum motorsports is a great place to ask about coil overs, or AJE seeing's how you've got their K-member. Ive had H&R race and super sport springs in a couple different cars, along with bilstien struts and shocks. I'll say that the spring choice isn't as important as what you use for struts/shocks. They can make or break it when it comes to ride quality.
  18. #43
    Grand Rapids, MI
    Dredging this thing back up after it appears somebody bought the last set of Delco 45H2082 wagon specific rear springs (hopefully it went to somebody here). I also see that Moog has discontinued the CC823 and those are not available anywhere. I did find that RockAuto does still have (5 in stock) a spring by Mevotech p/n SMS823V which I believe is the same as a CC823. I also saw a cross reference for the Delco 45H2082 to a Moog 8797, but the Moog 8797 is also discontinued. I did find a Duralast RCS8797S on AutoZone's website which I can only assume is equivalent to the Moog 8797.
    So it looks like if you want a really stiff rear spring the CC823/SMS823V is your option. I am assuming the 45H2082/8797 would be comparable to a stock wagon rear spring. Here is where I get confused. According to earlier posts in this thread there is also the Moog 8599 and a Delco 45H2040 which also looks to be comparable to the 45H2082, but it is listed for the earlier Fairmont 4 cylinder wagons only. Why would the rear spring for a Fairmont wagon be any different from the later LTD wagon??
    Ultimately the rear on my wagon is sagging and I'd like to get it back to stock ride height and weight carrying capability (not going to be hauling a boat, but we do use this for family vacations and road trips so it needs to be able to handle our gear). Does anybody have any ride/handling experience with the stiffer 823 springs and/or the softer stock springs? I'll admit the ride on this thing is pretty floaty right now, but it also has old shocks and tiny 14" tires which will both be changed soon.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '95 Saturn SW2
    '85 Ford LTD Squire
