I've got the carb dialed in what I think fairly healthy now on my 66. (5.0 roller crate motor)..the carb is very responsive with no hesitation.
Problem is, it runs like crap. It sputters and shakes throughout the rpm range.
the motor is a known good motor.
I'm running an 85 distributor through an autozone duraspark box into an accel coil.
The stock ballast resistor goes to the + side of the coil with about 7 volts going to it. I wired key on 12v to the duraspark box.
Will it run if I have it 180 out??
I can pull one plug wire after another, and to tell you the truth, it's like none of them make a difference at all, or make very little difference at all, so It doesn't seem to be just one cylinder or two that is the problem.
Weak spark?? How could I troubleshoot that?
Not sure where and how to start on this...Thanks again all!
