Originally Posted by
FuturaGuy
Don't give up yet. The only way you're going to get the wiring done is to do it yourself. Maybe Jay Leno can afford to have other people build his cars for him but the rest of us can't and we just had to learn how to do it ourselves. Keep in mind your new-found friends here on FEP want to see you succeed and we're here to help. We're not trying to bust your chops.
Electricity, especially a direct current system in a car, is not anything mystical and it's not that difficult, just tedious sometimes. Think of electricity as being like water flowing thru a pipe. Current is the amount of water, the flow. Voltage is the pressure, and resistance is the size of the pipe. Ohm's Law says current is equal to voltage divided by resistance so make sure you always have a resistance between the voltage source and ground. Otherwise current goes to infinity, voltage divided by zero. SHORT CIRCUIT!!!!
Every component, be it a light, an instrument, a motor, a coil, whatever, has current flowing thru it in a loop from the source (battery or alternator) back to ground. There's a Gozinta and a Gozouta. The current goes in, there's resistance of some sort (switches do NOT have resistance), and the current goes out at a lower voltage. Ford is fairly consistent with their wiring systems, using the same circuit number and color codes for wiring. Study it and work it system by system. Start with something simple, like the starter circuit. Using the EVTM's for both your car and the donor car, trace where the current goes starting at the battery until it goes thru the starter and goes to ground and then figure out where you need to make the connection between your car and the new engine's wiring. Do the same with the ignition system, the alternator, instruments, the lights, etc., one system at at time. AND WRITE EVERYTHING DOWN!!! If you take it one piece at a time, it not that bad. Trust me. And never be afraid to ask for help from the experts, the electricians in you Engineer battalion or the motor pool.
Good luck and keep us posted on your progress.
