This is my 86 GT, i bought it on my own, im using it as a learning tool. Its receiving the resto mod treatment, with an Explorer Motor and some goodies.
Parts Installed:
- Electric Fan
- Explorer Intake
- Edelbrock Heads 170cc IN. 60cc EX.
- Auto Meter 2 1/8 gauges, Oil Psi and Water Temp
- Trick Flow Stage 1 Cammm
- 24LB injectors
- A3m1 PCM
- BBK shorty headers Non-Equal
- Mac Pro Dumps
- 11" Fox brakes
- Pro M MAF 75mm
- 65mm Throttle Body
- ARP head bolts
- March Under drive Pulleys
- Hurst Short Throw Shifter + Hurst White Knob
- Console Delete
- o/r H pipe
- 190 LPH Fuel Pump
Mods Done:
- A/C Delete
- Smog Pump Delete
- 3.55 Gears
Some Day...:
- UPR Lowercontrol Arms
- UPR upper and lower control arms
- Coil Overs with KYB shocks and struts
- Maximum Motor Sports Sub-Frames
- SN95 Splindle swap with 13" rotor swap + 5 lug rear swap
