82 GS missing the door tags i'm going to guss they were removed when it was painted...found a stamped plate under the hood to the right of the hood release lever. Here are the stamped numbers....
609863
61H
B
103 1
611 TT
ST
AC 02
HB
O2V
-A
39
609863
61H
B
103 1
611 TT
ST
AC 02
HB
O2V
-A
39
"Strike First, Strike Hard, No Mercy Sir."
She's not an RS. I'll let Fox decode this since he knows more.
Does/did the car have....
front license plate bracket?
tinted glass? (factory, not aftermarket)
tinted windshield?
light group (light in glovebox, front ashtray, underhood)?
mirror on passenger door?
rocker panel molding? (if so, will be black)
AM, AM/FM mono, AM/FM stereo, or radio delete?
if AM/FM stereo, cassette or 8-track?
rear speakers?
premium sound system?
cloth, cloth + vinyl, leather, or Recaro seats?
urethane-wrapped or leather-wrapped steering wheel?
tilt steering?
interval delay windshield wipers?
TRX or 16-slot cast aluminum wheels, or steel wheels with or without covers?
if steel wheels w/ covers, spokes or not?
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
it was repainted so I'm not sure about the license plate..
the windshield is tinted but that is the only glass that is
no light under hood or ashtray or glove box
yes to Passenger mirror
Yes to molding
Yes to Am/Fm radio
yes to six by nines in the back
Yes to cloth and vinly seats
Yes to wrapped steering wheel
No Tilt
Yes to Whipers
Not sure about the wheels cause they say ford so they were put on after the fact
Re: tinted glass.....it would be a slight green tint, not a dark smoke tint that the upper windshield has. Does your side and rear glass have a slight green tint, or are they clear?Originally Posted by 81capri
Re: lights in front ashtray, glovebox, and under hood.....were there no wiring, sockets, and bulbs for each, or are the bulbs just missing?
Re: molding on the rocker panel.....it should be an added-on (painted black in your case) molding, not just painted rocker panel. So does the car have an added-on (painted black) molding on the rocker panel or no, and the rocker panel itself is just painted black?
Re: wrapped steering wheel.....is that urethane-wrapped or leather-wrapped? (urethane wrap and stitching is just molded/faux, leather wrap and stitching is real)
Re: wipers....by yes you mean interval/delay, correct?
Thanks!
The winshield is tinted up top it's kinda yellowish other than that the windshield is clear.....the side windows are clear.....hard to tell because of the faded after market tint on it....
saw no wiring for lights under the hood glove box or ashtray
The rocker panel is just painted black.....
urathane wrapped and stitching and it's coming off the steering wheel...it's the one where the center car covers the bolt that holds it inplace...
and yes to the wipers....they have three setting
609863 = 9,863rd '82 Capri assigned a VIN at Dearborn Assembly
61H = Capri GS three-door hatchback
B = 3.3L I6 engine
1031
611 = Medium Yellow exterior paint
TT = Tu-Tone Paint
ST
AC = air conditioning
02
HB = rear defrost
02 = no hood scoop
V
-A = Black interior trim
39
noy sure about the color cause it's green or teal now.....but everything else you said is correct.....thank you
Well, there's two possibilities there.....1) the tag doesn't belong to the car; OR 2) the car has been repainted. If that production sequence number matches the VIN, and you're sure the VIN hasn't been swapped from another car, you know it's not number one.
Exterior color code "61" is indeed Medium Yellow. That's an '82- and '83-only color code and name.
Well you have already decoded the vin for me......and as soon as I saw the color of the car I knew it was repainted poor job also......I was just cuirous as to what it was before the paint job....when i'm done with it only that tag will tell you what it was born as......I have a hood scoop to place on it.....and at some point a V8 will be going in and I'm goign to replace the rear end with a 8.8
