Results 1 to 11 of 11
    FEP Senior Member 8T6 SVO's Avatar
    May 2007
    El Dorado Hills, Ca.
    Default Name that part - need help with a few parts
    I received a few NOS parts the other day and need some help determining what they go to.
    Part #1/2 - this part appears to be a boost controller for an early turbo car. Part # D8AE-12A244-AA. It also has a boost solenoid attached E0SE-CIA.
    Part #3/4 - A relay of some type - E7ZF-17C476-AB.
    Part #5 - I think this may be a fan controller - no part # other than a 8GA stamped on the plastic case.
    2007 SL55 - Capri Blue - Leather, 487/560 WHP/WTQ at 13.5PSI
    3/4 is the wiper module. E7 = 87+ cars. No idea if it could be made to work on earlier cars.
    -Mike
    Jan 2006
    Western MA
    The part in Pic 5 does look like a fan controller for 2.3 cars. Show a picture of the underside of the board. When they go bad, they usually burn one of the traces.....
    1986 SVO Mustang - 1C
    May 2007
    This is a NOS one - no burnt traces - pic #6
    I did however receive another one in the same purchase that is burned like your describing - pic #7
    May 2007
    Here's a picture of a Fan controller for a 86 SVO. It's definitely different and smaller. 8 contacts instead of 10. I though maybe the fan controller above was for a car earlier than 1986 due to size. Hard to determine without a part number - I know.
    May 2007
    Quote Originally Posted by negusm View Post
    3/4 is the turn signal module. E7 = 87+ cars. No idea if it could be made to work on earlier cars.
    -Mike
    Thanks for the reply Mike!
    Honestly looking at that module wiper delay, I would nearly say that it might work in the eariler cars, it's a dead ringer except for the number stamped on it. It's probably just a different pin-out/wiring change, maybe a different connector. It might work anyways.
    Have you tried it? It would be good to know we can source that part from the later cars since the earlier ones are no longer available from anyone, Ford NOS parts places, etc. And used ones are dying as they get old.
    -Mike
    Quote Originally Posted by 8T6 SVO View Post
    No, I'm an idiot. It's a wiper module. How I got turn signal in my brain is beyond me.
    May 2007
    The guy that I got the parts from has all early turbo parts - 85 & earlier cars. So I really don't know why this part came with the stuff I got. From the type of parts sent - I would assume this could be a 87/88 turbo coupe part. But the ZF would mean Mustang right?
    Tell me the location of this part installed and I will check to see if it is interchangeable.
    It goes under the dash on the driver's side. You may have to search for it a bit.
    -Mike
    May 2007
    Mike -
    It's a dead ringer for the one in my SVO. Same connections, same box. I removed the fuse cover and steering panel to access, plugged the wiper module in and it worked - No longer NOS.
    My stock 1986 SVO came with a engineering # of E4ZF-17C476-AA - see picture in this thread:
    http://vb.foureyedpride.com/showthre...822#post747822
