Okay, I have a handful of problems with none other than electrical crap.
To keep it simple first and foremost problem I'm having is my alternator is obviously not recharging my battery. Brand new Optima red top, new remanufactured OEM alternator, new voltage regulator.
Have tested and got voltage to the alternator but when the car is started and then the battery is tested the voltage slowly drops, never goes even above 12.. not sure what else to look for, could it be something with fuses or wires? It doesn't make sense to me that that'd be the case since everything gets power just fine, just can't get it to recharge my battery. Maybe something not hooked up right? Would absent grounds in certain areas cause it to not charge the battery?
If any other info is necessary to try and diagnose this, just ask.
it's an 1983 Mustang GT 5.0 4 Barrel H.O.
