Results 1 to 11 of 11
    FEP Member 81capri's Avatar
    Sep 2008
    San Antonio, TX
    Default Bolts for hood Scoop
    Pulled the scoop off my 81 Capri and transplanting it to the 82. Some of the bolts are rusted and just bad...What can I use to secure the scoop to the new hood and where can I find the parts to complete the operation.
    "Strike First, Strike Hard, No Mercy Sir."
    FEP Power Member Motorcity's Avatar
    Sep 2004
    Longwood, Florida
    I recently transplanted an '83 scoop onto my '85. Some of the scoop's mounting studs were missing. So, I found bolts of the same length and thread, cut the heads off and then threaded them into the scoop. They worked perfectly. I'm not sure how the Capri scoop attaches so, I hope that helps
    1985 Mustang GT, owned since 1989
    2000 Expedition XLT 219k miles
    2011 Expedition XLT
    Sep 2008
    San Antonio, TX
    It helps alot....I just was not sure if there was a company out there that sold the bolts...but if all I have to do is find some matching bolts from a hardware store then I think I'm in good shape.
    Neither here nor there
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
    I know you can go to the junkyard and get them off tail lights or put up a Wanted in the classifieds, I am sure someone has something.
    Sep 2008
    San Antonio, TX
    The bolts off the tail lights will work as well
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
    Quote Originally Posted by 81capri View Post
    Psst thats what I just said..lol
    Sep 2004
    Longwood, Florida
    But, then your tail lights might fall off!! LOL!
    2011 Expedition XLT
    Sep 2008
    San Antonio, TX
    Yeah the tail lights falling out might be a problem
    Parts Destroyer gdniel's Avatar
    Aug 2003
    St. Augustine, Florida 32092
    I used the marker light studs from an 87-93 car that was in the junkyard, might even be the same as the tailight studs Jeff said to use.
    Fun is fun, and done is done!
    Found two of the 79 hood scoop rear studs missing.
    Holes are stripped and larger fasteners with glue fell out. Two of three stud repairs lasted one year.
    This time, replaced one using a household wall anchor and screw.
    Used a black nylon plastic push tree rivet and washer on the other. Tapped in w/rubber hammer. Is on there real good.
    Will see how these hold up. Will fill and retap if needed.
    Rear spoiler 84 and up is another source for the studs.
