Well I decided I wanted to run the Greg Weld wheels on the 83 so I decided to convert the front to 5 bolt. I saw that you can run Ranger front hubs so i went that route...what a mistake. I bought 88 Ranger 4 cyl 2wd front hubs, bearings, seal etc. Well for starters the Ranger bearings don't fit over the Mustang spindle, so while you do run the Ranger hub you have to run Mustang bearings. After i crossed that bridge, and was reassembling the brakes i realized that the diameter of the rotor was bigger than the Mustang so it rubbed on the caliper. Not only that but the rotor hat was larger in diameter and it rubbed on the outer brake pad bottom. So I got out the grinder. After taking off a pretty fair amount of material off the brake pad and grinding the calipers a bit, it still rubbed. Of course I didn't realize this until after I assembled everything and put the wheels on. It cleared when you rotated it on the car but the poorly designed brakes must move quite a bit when you apply them. SO as soon as i touched the brakes the rotor started grinding on the caliper again. I am pretty pi$$ed, this was supposed to be a "bolt on" conversion. Now i am ready to scrap it all and put on Aerospace brakes. I didn't really want to drop the $550 for the kit, hence the Ranger rotor attempt. Anyone have any tricks or ideas besides changing to 94-newer spindles?? I have decided to just drink beer and shake my head right now. Here is a couple pics with the wheels on.
