Well I've had this thing for about 2 1/2+ years now and supposed to be coming back from the body shop next weekend.
I drove this 56K mile V-6 car into my garage and tore it down to pretty much a rolling chasis
I have pics but only one I have now is of the day it was picked up to goto the body shop.
It will be getting a two-tone paint with black on the bottom and dark shadow grey on top with a red pin to seperate
Here's a list of parts I've secured for it. I have everything cleaned painted and ready to start to put back together when she comes home
My goal when I pick it up sat morning is to have the engine, trans, driveshaft and exhaust put on before I sleep on saturday night.
Mod List
Under Hood (Engine bay is smoothed no Swiss cheese)
Barry Grant Speed Demon 650
Jegs throttle bracket
Victor Jr. Intake w 1inch spacer
AFR 185 Heads w 1.6 rockers
347 Stroker (cat nodular crank 3.4 stroke, hawks 4340 h beam's, probe forged pistons, comp solid roller bar-type lifters, comp cams custom solid roller cam, billet double roller timing chain and main girdle)
(282/286 duration, 609/618 lift, 110 lsa.)Cam specs.
Moroso 7qt oil pan
110 GPH Holley mechanical fuel pump
Holley FPR with carb mount
MSD 8598 dizzy
March Alt bracket
FRPP AC delete Bracket
SFI Balancer
Griffin Alum Rad
MSD 6al
MSD Blaster 2 coil
Spal Electric Fan
Spal fan controller setup with two speed relay turn on
Relocated battery to trunk
Mac Shorty Headers
off-road h-pipe
American thunder catback with tailpipes
Optima Red Top
Rest of the drive line
Hawks Racing 8# aluminum flywheel
Spec Stage 3 clutch kit
WC T-5
Adjustable clutch cable
Billet quadrant
B&M Pro Ripper Shifter
FRPP Alum HD Drive Shaft
8.8 4:10 Gear with a (rebuilt) trac-lock
5 lug axles
Brakes and Suspension
Eibach Sportline Springs
Racecraft cc plates
Racecraft bumpsteer kit
sn95 spindles, hubs, calipers and rotors
All new brakelines
Basic drum setup on rear end with organic shoes and new hardware.
Weld in sub frame connectors
Double adjustable upper and lower control arms
Exterior stuff
New two-tone paint wet sanded and buffed 4-20-09
86 LX front and rear bumper covers and body molding
HO Fibertrends 3" cowl hood
89 Vert doors (on the door mirrors)
87-93 quarter windows
New trunk lid
All new weather stripping (t-tops, doors, trunk)
84-86 Taillights
FR500 17x9 wheels black with the polished lip
Inside
85 GT grey dash
Black dash pad
Console delete
85 gt leather wrapped steering wheel
93 cobra greay leather seats (drivers 6 way adjustable)
new black carpet
83 black manual door panels
83 black interior quarter panels
new black headliner
new black door seal plates
Custom rear seat delete
Oil pressure and Water Temp in dual pillar pod (carbon fiber)
