What is the issue that requires a special distributor? I am guessing it is interference at the dist. hold down, but I have not been able to confirm this.
vic jr water passage sits higher than a normal intake. you can you a small diameter (stock) or the special MSD dizzy.
82 Capri RS, 5.8L, solid drop mounts, areomotive fuel system, 3" exhaust, ROD six speed, MM torque arm suspension, "mathis" 90 k-member, 04 cobra control arms, h&r springs, koni shocks, m-2300-k, caged, battery relocate
