Results 1 to 13 of 13
    Question Ford Relay ID for Amp Ratings?
    Where can I find information on current (Amp) ratings for factory Ford relays?
    I have over a dozen Ford relays I have picked up over the years and need three or four for a project but do not know what they are rated at.
    I have tried Motorcraft.com. Absolutely no help...
    Is there any Ford Part number gurus out there?
    Thanks.
    I know of no rating chart for them. Ford pretty much just says what application they are for (headlights, horn, etc) and not what they're rated at.
    Is there anywhere I can look up the part numbers I have to see what the relays were originally controlling?
    Have you tried www.motorcraft.com ?
    '79 Pace Car 5.0 (well 4.2 until better days)
    '80 Capri 2.3 (sold ) - '79 Hatchback 2.3 (sold ) - '80 Notchback 3.3 (junk yard )
    Motorcraft? Never heard of them.
    Parts Destroyer gdniel's Avatar
    Aug 2003
    St. Augustine, Florida 32092
    What are the part #s, I have labeled all the ones I saved, and may be able to help you out a little.
    Fun is fun, and done is done!
    Usually the std for the higher amp OEM relays is 30a. aka fuel pump, main EEC power, etc. The headlights never had a relay.
    Quote Originally Posted by ricko302 View Post
    Do you have the part numbers?
    Or are these numbers stamped on the parts themselves?
    The numbers stamped direcly on the relays are engineering numbers and can be tough to cross reference....if at all.
    -Mike
    Here is three that I could get to easily. There is more buried in my stash of parts.
    E6VB-13A025 AA
    E5DB-11433 A2A
    E5VB-13A025 AA
    FEP Super Member MurPHy's Avatar
    Dec 2004
    West Deptford, NJ 08096
    All Ford relays are 30 amp. Ford has been using the same relay design for years now.
    1990 Mustang LX 5.0 - Ran into a tree (fixed!)
    2005 Ranger XLT 4x4 - Daily Driver/Tow vehicle
    1992 Mustang LX 2.3 - MPG baby yeah!
    1994 Explorer - Fix 'n Flipper
    These relays are all 1980s style I am considering.
    I have some relay connectors with 18 ga. wire and some with 10-12 ga wire.
    Having different part numbers makes me believe that these relays have different ratings.
    Sep 2005
    Mtn Home Air Force Base, Idaho
    i agree with murphy, 30 amp standard. wiring differences could be attributed to actual load, not relay rating.
    66 7 Liter Galaxie 4 sale
    66 T-bird 4 sale
    67 GT500 clone
    68 Cougar 302 c4
    72 Pinto 2.3 turbo soon
    79 2.3 Turbo Pace Car
    83 5.0 5spd GLX vert
    83 GT 5 spd blk/blk
    84 GT Turbo vert
    84 v6 to 5.0 SROD hatch
    84 5.0 5 spd LX cpe
    86 Capri bubble butt, painted!
    86 5.0 5spd LX hatch
    89 5.0 aod LX hatch GRM $2007 entry 12.57 @ 111
    89 2.3 auto cpe w/v8 susp/brks/strng 4 sale
    90 5.0 aod the "cruck" a little bent
    86/90 GT 5spd, 90 met a phone poll
    92 5.0 5 spd LX coupe
    97 Taurus SHO, i weld cams
    www.j4jps.com
    Go to this site https://wellsve.com/parts/
    Enter FORD part number then look for application.
    Search OE Part Number
    Well Part Number - Cross Ref
    Name:  19273 WellSE.PNG
    Specification
    Name:  19273 40Amp.PNG
