Hey guys,
I bought a little universal Sunpro 3 gauge pod with oil pressure, water temp, and volt meter in it. I got q's on installation of all 3.
1st, voltmeter, seems simple. Ground it and wire it in with a fuse box accesory. Seems simple. One thing, I have a cb wired into the fuse box and I have one of those accesorry fuses that has a wire coming out of it to wire things in. Would it be safe to put the gauge on that fuse with the cb on there or should I get another one of those fuses?
2nd, is my 86 engine microprocessor controlled? It says with the oil pressure gauge to be sure that the microprocessor controled engines can accept aftermarket gauges. Can it?
3rd, for the water temp and oil pressure it tells me to wire them into the warning light sender. Where would these be for oil pressure and water temp?
Any other helpful hints on gauge installation is more then welcome!
