Hi Guys,
Thinking of upgrading my SN95 brakes to the cobra brakes front and back.
I have 1996 spindles so the 13" rotors and PBR calipers should bolt straight on.
On the rear I have a 1995 GT axle with the 10.5" rotors and varga calipers. I have already got a pair of cobra caliper brackets aswell as the anti moan brackets. For the rear I just need the 11.65" rotors.
My only concern is regarding the master cylinder and booster.
I have on the car at the moment a remanufacted 1980 booster which I believe is the V8 booster. I am using a 1985 towncar 1" master cylinder. The proportioning valve has been removed and replaced with an adjustable valve with a tee piece to split the line into two pipes.This set up is poor because I have next to no braking force on the rear discs even with the valve set up for maximum brake pressure.
I am therefore thinking of fitting a 1995 cobra master cylinder onto the 1980 booster.Can anybody suggest if the 15/16" or 1" cobra master cylinder will be the best to fit on this setup?.
Thanks for any help you can give,
Blacktop.
