Heres the deal, Trying to start after sitting 6 months and it wont fire up. i noticed that My clear fuel filter is not completely filled with gas like normally. I have an Eddy 1406 on it and I do have a Holley fuel regulator on it set to 5.5psi. Is it possible that a fuel pump just goes grows weak over sitting ? I pulled the line and turned the key and the fuel comes out of the line like soda coming out of a bottle. I tried shotting a good amount of starting fluid and nothing happened. I pulled a plug and they were not soaked. I even used the screw driver trick and nothing. I also took apart the Holley fuel reg and nothing seemed irregular. Is there anything in the tank that could be the problem ? The coil is very newer but I dont think it is an electrical issue. Also just to make sure the clear glass filters have in and out on them, so i assumed in goes the fuel and out goes to the carb right ?
