New User
c5 transmission issues
Having problem with c5 transmission. Does not want to shift out of first when cold. Trans fluid has been changed including torque convertor, new filter and new transmission modulator. Car shift fine through gears once warmed up. Any ideas?
New User
relax, not everyone can have their questions answered right away.
are you sure the fluid level is correct?
will it upshift when you manually shift it?
was it ever rebuilt?
it may just be getting tired.
http://Clickclickracing.com
A forum for auto mustangs. They can help there.
try adjusting the front and rear bands to see if it helps and is the fluid level ok if it is it sounds like its time to rebuild
o make sure you got the modulator line back on good
- You may not post replies
- You may not edit your posts
Forum Rules
