Ok, new cam is in, gear drive is in, then this....I dropped that tiny bolt that locks down the dizzy, it went down either one of the 2 front holes that are in the center of the motor that run parralel with the cam, or down one of the lifter holes. Now when it did this I heard what sounded like a bolt hitting the oil pan.
Now here's the question; is there a windage tray, or is it posable that the bolt did go right through the motor and land in the oil pan? I can't really see anything else that would stop the bolt?
I spent the last couple of hours with a couple of different magnets, some on a ridgid rod, others on a flexable rod, all with no luck. I went in both oil drain holes as well as the big gap in front where the timing cover would be.
You guys have any other idears on what to do? I am trying to stay away from dropping the oil pan as that is a royal pan in the butt!
If I pulled out the cam again, is the motor set up so that you can look down those center holes right into the pan?
All I need to do is be able to see it.
Other than that, what do you think would happen if I drove it like that?
Thanks again guys
