Would a intercoolcer make a difference on a nmaturallt aspirated car? I havent figured out how to design a way for it to work.
Nope, won't work.
Best you can do is "cold air induction".
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
I had this crazy idea once to use my AC as a way to cool intake air but it never made it out of my head. I also had a similar idea of using AC to blow cold air down onto a Turbo Coupe intercooler on my Merkur but again that one never made it out either. Now neither car has AC so neither one will happen.
I know everyone says it wont work, but the honda types have setups like that all the time for the N/A cars.
1985 Capri RS 5.0 5 Speed
1994 Thunderbird LX 4.6
1978 Country Squire 7.5
2004 Mustang GT 4.6
cold air induction is about as good as it gets for a n N/A car. the point of an intercooler on a turbo car works because the turbo is cooled by the antifreeze/water mixture from the block/radiator.. meaning the air gets warm. an N/A car doesn't warm the air at any point until it gets to carb/throttle body, so an intercooler would basically be pointless.
82 Capri - 306, C4
85 Bronco mud truck
88 S10 minitruck
94 shortbed F150 mud truck
CK Performance & Minis
---===== stop convert to HID, H4 + relays is the way to go =====---'79 Pace Car 5.0 (well 4.2 until better days)
'80 Capri 2.3 (sold ) - '79 Hatchback 2.3 (sold ) - '80 Notchback 3.3 (junk yard )
The reason for an intercooler is to cool the air charge. Not because some turbos have coolant going through them. Building pressure creates heat, and when you start running big boost it creates more heat. Take the turbo to the topend of efficiency range and you will create alot of heat. The more heat you force into the motor less power it will make. You could safely run 7-8lbs with no intercooler.
Yeah Honda guys are know to use interfoolers. The AC idea isn't worth it becuase of the drag from the AC compressor.
1984 SVO - .63 T3/T4, NPR, LA3, Boport 1.5
1984 GT - 306
84 Capri RS T-Roof 351c
95 Cobra Two Top #167
Just remember that the rules of thermodynamics apply to our cars.... You CANNOT cool air (or anything else) below ambient with nothing but ambient air. If anything you will heat it slightly from the restriction of flowing though the intercooler.
On the same note Wind Chill dosen't apply to your car
It puts the ATF in the T5... IT DOES AS IT'S TOLD!!!!!
82 Capri - 306, C4
85 Bronco mud truck
88 S10 minitruck
That was pretty much what i came to. The only thing i thought was with the intercooler it might cool the intercooler enough to cool the air enough and in turn make enough power to compensate the AC and a bit more than it would be without the AC, but if i'm gonna go through all that trouble i'd just get an air to water and call it a day.
You can go with a water to air IC (or is it the other way?) anyhow then youd have to make sure there is a cold water tank with ice in it ...IMHO not worth the money or the hassel for a DD..BTW hondas need all the help they can get they need to put a R in the gas ...it gives them like 25 hp....Oh sorry...
I could use that Honda intake, Ive drawn up some stuff like that and have been trying to desing something like that who makes it? I thought air to water I/C's worked with the water pump? I thought about using my thermactor if I can find where its at like a super charger.
The most efficent air intake tract is one that has LEAST possible amount of tubing and the STRAIGHTest possible path to the cylinders. The more tubing and the more radiuses you put in that path, the more resistance the air will encounter, thus decreasing the highest possible airflow AND heating the air up more than necessary.
You're going to spend a lot of time and money for nothing, to add an "intercooler" to a naturally aspirated engine. You're going to heat the air up with all that extra tubing and all the extra bends in, and having to go through a heat exchanger, only to then try to cool it back down to where it was at the beginning of this whole rigmarole. This and every other "trick" to re-invent the wheel, including using the air conditioning or Thermactor air pump as a "supercharger", has been pondered long before now, and dismissed as tomfoolery
I declare Shenanigans!!
2004 Mustang GT 4.6
The picture looks like an air filter to me, not an intercooler.
1985 Mustang GT:
347 stroker
Holley 750 double pumper
xe274hr comp cam
Victor jr. intake
RPM aluminum heads
roller rockers
equal length shorty headers
electric fan
afco aluminum radiator
american thunder series flowmasters
pace setter off road h-pipe
chrome OEM cobra rims
