Well I have done some searching and was reading about the upgrades, but I am confused about my situation.
My headlights don't work and I think I might have it narrowed down, but I wanted to ask you guys first.
First off its a European spec car and it has different headlights in it.
I am not sure what is stock but I have regular beams are 3 prong and the highs are 2.
I have a Cobra but there isn't any fogs installed and when I pulled the old switch out it appeared to me that its one that isn't for fogs.
So I ordered and installed a new one just like it hoping that my lights would work. no luck
So I start digging around and find this. Is this what you would consider the upgrade?? Could these be the problem why my lights aren't working. All my lights work except my head lamps. The lamps work when connected directly to the battery.
This was mounted to my D/S strut tower on the back side
I only have power going into the right one at one connector when the light switch is on and I don't have power any of the rest of the connectors.
I guessing that these are bad but wanted to ask some of the more experienced here.
