Where is the ID Tag Located on the Transmission?
Own: 1979 Mustang Ghia 200CI I6(in Process of Restoration)
Have Access to: 2002 Ford Mustang GT 4.6L V8 Laser Tint Red, Leather Medium Parchment Interior, 3.27 Locker Rear End, Mach 460 Sound
Bolted to the top cover.Originally Posted by digitalrailroader
Is it hard to get to?
I haven't had a chance to get my 85 out of the garage to get you those pics,but soon I hope.
I just joined the forum and would like to help you with your data collection. I ordered my 79 Cobra and kept all the documentation on the car. It is all original, so I should be able to find whatever tags that are visible. Do you want me to post the build sheet, window sticker, and pictures here or just email them to you? Any other data you want?
I'd think emailing might be best for this particular project, but if you're willing to post, all us nosey lookie-lous would love to see anything you'd be willing to share. Maybe start a thread in the Cobra Corner for documentation for the heck of it?
Do you want any info from the Fairmont/Zephyr/LTD/Marquis?
1977 Oldsmobile Vista Cruiser
All of these pic are from my 81 Zephyr. It has a 2.3 and is 95% percent original. I repalced the factory plug wires this past fall...still have them if you want pics. But there is something that I would like to know, the number 351 appears on the car twice, first on the door tag and second behind the air dam. (have pics of both below). Can someone tell me what that number means?
http://i78.photobucket.com/albums/j1...yr/tags010.jpg
http://i78.photobucket.com/albums/j1...yr/tags011.jpg
http://i78.photobucket.com/albums/j1...yr/tags012.jpg
http://i78.photobucket.com/albums/j1...yr/tags013.jpg
http://i78.photobucket.com/albums/j1...yr/tags014.jpg
http://i78.photobucket.com/albums/j1...yr/tags016.jpg
http://i78.photobucket.com/albums/j1...yr/tags017.jpg
http://i78.photobucket.com/albums/j1...yr/tags018.jpg
http://i78.photobucket.com/albums/j1...yr/tags021.jpg
http://i78.photobucket.com/albums/j1...yr/tags025.jpg
If you need more just let me know, almost all tags/numbers are visible on my car. Oh and the Buck Tag it was stuck on the drivers side fender, where it mounts under the hood. Wasn't bolted or anything just wedged between the fender and the body. Plus of your interested I have access to about a 20 different Fox cars. Pretty much everything minus the Stang/Capri/Zephyr/Fairmont.
These are the only ones I have on my 86 ASC McLaren Capri. The pic of the door sticker didn't come out. It is faded....BAD and you can only make out certain things. The buck tag was in the usual spot on the core support. The ASC tag was next to it, but was removed and lost (Doh!) Click on the pics to enlarge
You can get pics of my SSP buck tags on my cardomain page, page 2.
heres a pic of my buck tag and where I found it along woth some #'s I found stamped on the fire wall
the buck tag reads as follows
MUSTANG
106014 61B F TR 0044
277 DF ST
04 HB S
GT BR MOD 03 V
S -D NLR
it was held on by a screw
the fire wall pics are what looks like an AC (upside down)
(below wiring) 3RB36
(above ground strap)8 31 03 also upside down
and on rad support what looks like 58DB
hope this helps. the car is an 83GT with a v-8 manual trans, no air.
My 82 Capri. 302, 4 speed, T-tops, no A/C, possibly radio delete.
Buck tag
LH valve cover
CF335AB______\ C \ ??
ABCDEFGHJKLM\ R \10
123__________\-- \--
1234567890 12_\ S \27
RH valve cover(can't read anymore)
distributor
1J___30
_E2ZE
_12127
__DA
Buck tag location
I can't get to the trans or rear diff yet, I'll make sure to take a look when I get it up in the air though.
I was at the junkyard over the weekend...found a complete 1980 Fairmont.
There was the owners guide and build sheet right on the front seat.
I will be honest, I left it there, I don't know why, but I did.....
Anyway I was YELLED at by some person on this site for not grabbing it.
I won't mention any names skye cough cough
Well I went back today and got the Owners Guide, Build Sheet and the Buck Tag.
I am sorry on the crappy door sticker pic, but all I had was my cell phone.
I think you can make it out now that I adjusted the pic a bit.
Buck tag was located on the top of the Rad support, flat on top right.
Pics of the car are in the FYI section now incase you want to compare anything.
CLICK TO ENLARGE
The picture isn't the best so Ill write the numbers down too.
9R03W157773 3JA B
W6 A 9 K QS
BPF C
MOON COBRA
Here is also a tag that was under both driver and passenger side fenders. These tags were right on the top rail about a third of the way back from the front. Also in the middle of the bucktag were a backwards stamped F and 8.
Could you also tell me all of the options (windows, locks, radio, ac, cruise, defrost, louvers, console, power brakes, etc.) the car has that you can find/think of, and the interior and exterior colors and color of any pinstripe or bodyside molding tape insert, type of wheels (TRX or other), etc., etc.? Very little is known about the early (pre-'82) Body/Buck Tags or the San Jose assembly plant Body/Buck Tags. Your extra help is appreciated!
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
Manual windows, power locks, no radio in the car when I bought it but there is wiring and there were 4 speakers in it, has ac, no cruise, defrost, louvers. I have the console and power brakes. The color is the deep blue, black lower, (Cobra package). The stripes on the moulding are a light blue painted on stripe. Bucktag was screwed onto the front of the radiator support by the headlight bucket on the driver side. Interior is a light blue.
I can't think of anything else off the top of my head Foxchassis. Would you like carb tag pics or factory sheetmetal stamping pics too?
Warranty Tag sitting in a stang at the bone yard
I'll get pics and info from my 85 GT 5.0 CFI. I have the engine out and apart, and trans is out also. My dad originally bought the car and now I have it, so I know everything is original. Well, the exhaust isn't, but thats the only thing that has been changed at the moment. Hope it helps. But, I won't have pics for a couple days as car is in storage.
Justin
Alright, I told FoxChassis I'd post this up so here it goes. First is for this car:
Sorry this is sideways I couldn't get it large enough to read if it was up and down so.....
Now this car:
I have the window sticker for it, and a ton of other stuff from the original owner too, but the sticker is pretty brittle and wrinkled. You can make it out fine if you have it in hand but my scanner didn't like it.
For this car:
All I have is the Buck. No paperwork and the door tag is delaminated and illegible.
My tan hatch had the buck put behind the rad support during the body work so I can't get a decent pic of it. I have no other info on that car either. So, here you go, use the info for something good.
84 Tan 5.0 GT hatchback
84 Tan 5.0 GT convertible
84 GT350 2.3T convertible
this is the info from my recently acquired 1981 ghia coupe, it's undergoing restoration at this moment, im in the need of the owners manual, here in Venezuela its hard to find, anyone of you can help me with this? many thanks
Fox, I realize this thread began a year and a half ago... are you STILL collecting this info? I can get you info from my own Capri,vin and buck tag ,and one of my Mustangs if you wish
Tan84..something caught my eye looking at your white turbo hatch...what happened to the side moulding? Then I saw in your album,the pic of it on the showroom floor,and it is the same. Whats the story behind that?
