Results 1 to 7 of 7
    FEP User CKJ's Avatar
    Dec 2006
    Pasadena California
    Default 86 Capri Header panel
    Howdy all.. I found a small crack and portion of the front headlight header panel that is broken on my 86 capri. I was told by matt that the 85 86 NOS gt headlight header panels that he sells wont work on the capri? I thought they were identical except for the grill that bolts onto it? Can someone clarify the difference as I'm truly a newbie in this department.
    For reference, here is the link to the 85 /86 gt headlight header panel for sale at foxmustangretoration.com that I was looking at.. http://www.foxmustangrestoration.com/?p=vp&id=479
    He's right. Capri headers are unique.
    I have a similar issue with a spare I have. I was going to repair it with some fiberglass repair.
    If anyone has a better fixing prodect, LMK please.
    -Mike
    FEP Supporter Mustang Marty's Avatar
    Nov 2004
    That is why I take any good Capri header panels that I see my local yard.
    While the Capri header is similar to the 79-82 mustang one, the reason they are different is due to the fact that the nose on the Capri is vertical and the Mustang slopes down. I compiled a pic below to show the difference.
    Since the Mustang's is designed to have a mounting point for the side marker there is extra material there that prevents the Capri cover from fitting. The header isn't thick enough to cut it down to make it fit. The 83-86 would be even more difficult to modify since it doesn't have provisions for the headlight trim.
    01 Mustang - True Blue - 3.8 Auto - Purchased 2001
    68 Mustang Coupe - 302 Auto - Owned 1980 - 1981
    Dec 2006
    Pasadena California
    Thanks for the good explanations guys..
    Also, the Capri panels have subtle changes over the years. Nothing earth shattering I think but I know that the 84 one I had was different in certain spots compared to the 85 one I had. The changes shouldn'a affect installation from what I could tell.
    -Mike
    Sep 2005
    Mtn Home Air Force Base, Idaho
    i have one from an 86 that is getting an 86 stang nose. email me for pics. jj.johnson@Mountainhome.af.mil
    66 7 Liter Galaxie 4 sale
    66 T-bird 4 sale
    67 GT500 clone
    68 Cougar 302 c4
    72 Pinto 2.3 turbo soon
    79 2.3 Turbo Pace Car
    83 5.0 5spd GLX vert
    83 GT 5 spd blk/blk
    84 GT Turbo vert
    84 v6 to 5.0 SROD hatch
    84 5.0 5 spd LX cpe
    86 Capri bubble butt, painted!
    86 5.0 5spd LX hatch
    89 5.0 aod LX hatch GRM $2007 entry 12.57 @ 111
    89 2.3 auto cpe w/v8 susp/brks/strng 4 sale
    90 5.0 aod the "cruck" a little bent
    86/90 GT 5spd, 90 met a phone poll
    92 5.0 5 spd LX coupe
    97 Taurus SHO, i weld cams
    www.j4jps.com
    Quote Originally Posted by stormy69 View Post
    Why?
    Is that 86 Capri the one in your sig your going to change?
    Cmon! Don't do it!
    -Mike
