Page 4 of 4 FirstFirst ... 234
Results 76 to 97 of 97
  1. #76
    How did they fit?
  2. #77
    FEP Power Member LTDScott's Avatar
    Oct 2004
    San Diego, CA
    Yup, 245/45-17.
    85 Ford LTD LX: Four eyes and Four doors
    EFI swap, AFR 165 heads, 5-speed conversion, Cobra brakes, etc.
  3. #78
    Got my one Dodge wheel in yesterday and as soon as I find a used tire for it and finish my five lug I am going to do some testing. I am going to try a 235/45 in the front because I want to lower it. Maybe a 255 in the rear depending on how that fits.
  4. #79
    FEP Power Member David Claflin's Avatar
    Oct 2008
    Redneck Riviera, Fort Walton Beach Florida
    I know it's old, but in case anyone was wondering you can get the ford CVI and mopar style 17" steel wheels through summit.
    These are ford type, have the 6" BS, so will be tucked under the car better.
    https://www.summitracing.com/parts/r...-108/overview/
    These are the mopar style, has the 4.5 backspace, so looks like more of a dish, and will have a wider track.
    https://www.summitracing.com/parts/rnb-939-137
    1985 LTD LX, Mach1 brakes, 17" Mopar police car wheels. 302, T5, 4.10s
    1986 FHP coupe, stock shortblock, TW heads, Holley SMII intake, 4.88, T5Z
    1990 Red LX, ported AFR heads, TFS-R box upper, weenie cam, 1 3/4 long accufabs, 3" exhaust, T5, 4.56
  5. #80
    Grand Rapids, MI
    I thought the '03+ 17" CV steel wheels had too much positive offset to work (+44.5mm)? It looks like the Chrysler wheels have a lot less offset (+21mm). I am planning to run '95 front spindles with fox arms and fox length axles in the rear and was resigned to running '98-'02 16" steel wheels. I had completely forgotten about this thread.
    The older 16" Ford steel wheels have +12mm offset according to the answer by a Summit tech in the Q&A section.
    https://www.summitracing.com/parts/rnb-939-131
    And confirmed on the Dorman site.
    https://www.dormanproducts.com/p-660...eel&origin=YMM
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
  6. #81
    I’m running the later vic wheels to accomodate cobra brakes. Up front I had to run 25mm spacers and out back I have the cobra irs. The wheels are tucked but fit.
  7. #82
    FEP Member never's Avatar
    Jan 2014
    Bragg Creek, AB
    Or get them modified and they'll fit however you want! 5" up front and 10" wide out back.
  8. #83
    Quote Originally Posted by never View Post
    That is badass! Not exactly a sleeper.
  9. #84
    Jan 2014
    Bragg Creek, AB
    Quote Originally Posted by nelzfoxes View Post
    Thanks...even with the chute off, if you know what you're looking for, it's not really a sleeper. And when it's running, it's definitely not a sleeper!
  10. #85
    Oct 2004
    San Diego, CA
    Funny that this thread has new activity. I recently swapped my rear brakes to SN95 Cobra with Fox length axles and long wheel studs, so now I can run pretty much any rear wheels I want. But since I originally posted this, I've installed a MM tubular K-member and '96 spindles, so my front track width is a bit wider than before.
    I now want a second set of wheels for my car so I wanted to revisit what these Mopar steelies look like on my car, and I'm reminded how much I like them. I'm just not thrilled about the idea of 245 tires on 7" wheels.
    I also find it odd that Dorman lists them as 5x114.3 lug pattern whereas the stock Mopar wheels are 5x115. I wonder if they're just rounding up?
  11. #86
    I am gonna have a set done in white with some track day tires!
  12. #87
    Oct 2008
    Nice, who did you have modify them? What size tire are you running on the front?
  13. #88
    Jan 2014
    Bragg Creek, AB
    Quote Originally Posted by David Claflin View Post
    Gary at Pico Wheel in LA did them. The front tires are MT Sportsman SR fronts 26x6.
  14. #89
    Oct 2004
    San Diego, CA
    How much did the widening cost?
  15. #90
    Jan 2014
    Bragg Creek, AB
    Quote Originally Posted by LTDScott View Post
    It wasn’t cheap but I can’t remember exactly...I think I figured out the price after exchange and I’m pretty sure it was $900 Canadian.
  16. #91
    Oct 2004
    San Diego, CA
    Ouch. I've heard they raised their prices recently. Not keen on spending more than the cost of wheels on widening.
  17. #92
    Jan 2014
    Bragg Creek, AB
    I got the wheels for $50 so the work was MUCH more than the cost of the wheels! And it sucked paying for shipping to/from Canada!
  18. #93
    Oct 2008
    I know it's of no help now, but for anyone else who wanted to get wheels widened, I asked Stockton wheel about widening the 17x7 to a 17x8, and they said it would be $150 per wheel.
  19. #94
    I'm looking into potentially a 92 Mark VII rear for my build and some 17" crown vic steelies...now after reading through the whole thread, sounds like would have to run 235s to be safe? I haven't bought either of the two things yet so dropping in for consultation to make sure I don't end up in a dead end road.
  20. #95
    Chrysler wheels are like +18mm offset. Crown Vic (03+) I have seen +43mm, consensus seems to be varies between +40-50mm.
    If anyone wants to buy a set of Chrysler 300/Charger wheels off of me, and you're near the midwest...they're for sale. I still want to see the two wheels side by side, because if the diameters of the 10 holes are the same, and the spacing of their centerline around the hub are the same, and the bulge around the hub a similar diameter...the crown vic wheels might be my answer for the rear but the 300s the answer for up front.
  21. #96
    If anyone's interested, my Charger Wheels are now for sale - http://vb.foureyedpride.com/showthre...s-City-Kansas)
  22. #97
    I did a comparison video since I had both on hand of the P71 wheels vs the Late model Charger Wheels - https://youtu.be/5fs7X_RIOls
