Page 1 of 4 123 ... LastLast
Results 1 to 25 of 97
    FEP Power Member LTDScott's Avatar
    Oct 2004
    San Diego, CA
    Default 17" steelies on the car
    I decided to throw some tires on the 17" steelies referenced in the other thread and put them on the car:
    I think it looks really sweet, but I need a little more positive offset cuz the rear tires rub up inside the wheel well over bumps. I'm kinda bummed. These would probably fit perfectly on 5-lug Fords that don't have 96+ front spindles/control arms and Mark VII rear ends (which my car has).
    Part of it is has to do with the fact that I'm running 245 tires on 7" wide wheels, but I like the "flared tire" look. If am to keep these wheels, I may have to step down to 235 tires. Not sure if I want to do that.
    Regarding lug fitment... I painted the lug nut seat on the wheel with some red paint and tightened it up. Undid the lugnut and saw that the lugnut had contact all the way around. Probably helps that the hole itself is rather large and allows the lugnut to "sink in" a good amount. You can also see what .7mm difference looks like.
    As promised to Dean, I tried the center caps from my dad's Crown Vic and they fit fine:
    I would like to see what the flatter center caps that the CVPIs actually use would look like on here.
    And here's the comedy Dodge hubcap option. It's just propped on there because I'd need the special collared Dodge lugnuts to make it work.
    More pics here: http://www.ltdlx.org/gallery/magnumwheels
    I'll run these wheels for a while but I dunno if I'm going to keep them or not. I really wish I could find a set of Crown Vic 17" steelies cheap.
    85 Ford LTD LX: Four eyes and Four doors
    EFI swap, AFR 165 heads, 5-speed conversion, Cobra brakes, etc.
    FEP Super Member 93-331-29PSI's Avatar
    Dec 2005
    Chesapeake VA
    Would rolling the fender lip make a difference? I agree that the Crown Vic steelies would probably be ideal with the 96 components and Mark VII length axles, but the wheel center is almost flush with the lip which would look odd.
    83 GT Turbo
    Oct 2004
    San Diego, CA
    Quote Originally Posted by 93-331-29PSI View Post
    It's not hitting the lip. It's rubbing up inside the wheel well in the "flared" part of the body when going over dips and bumps. Probably didn't help that I had my old wheels in the trunk while driving around.
    FEP Power Member Ltngdrvr's Avatar
    Southeast Texas
    Looks just like I had said all along, they fit the studs just fine with absolutely no issues at all.
    Those wheels definitely give it that "cop car" look...
    FEP Power Member Zephyr 351C's Avatar
    Sep 2002
    Western NC/East TN
    Dang it Scott! I might have to get a set for my 81...
    That looks mean.
    -Zach
    '81 Zephyr Sedan: In pieces. Some at the garage, some under my bed, etc...
    evil. i like it.
    1984 LTD Wagon - S3AHAUS
    1988 Mustang LX 5.0 Hatchback - NOBIMMR
    1997 BMW 318ti - TinyBimmer
    2001 BMW 325i Wagon - ANTICW
    FEP Super Member eric5oh's Avatar
    Mar 2004
    Saint John, Indiana, United States
    I like the steelies. I think I'm gonna get a set for the Fairmont
    FEP Power Member Peganit2's Avatar
    Davison, Mi
    You gotta find a way to make that work because that looks Awesome!
    Looks like a car Clint Eastwood or Burt Reynolds would drive in the movies.
    Tough.
    The aluminum look doesn't do it for me.
    On closeup that is one clean car! Your exposed metal isn't even rusted. Man here in Mi. even the new cars setting in the dealers lots have more rust! Whats considered a good Mi. car is one that only has a few small rust holes.
    Current list o' cars
    87 hatch california car 94 SHO Taurus DD 96 Aerostar FH 77 HighBoy with a BBF
    Memorable cars from my past
    69 stang sports roof 302 GT RARE! 63 XL Galaxie loaded 75 Torino with a BBF 80 Capri coupe 82 stang hatch Turbo conversion car 82 Escort with a 2.3 85 'stang coupe with a 4.6L 4V Cobra motor 85 LTD with a 302 67 'stang coupe roller 61 Starliner Galaxie with a 428 SCJ 72 'stang sport roof
    FEP Power Member white1983GT's Avatar
    Sep 2003
    Dothan, Al
    those look JUST like the wheels on my 07 CVPI, ....and look hawt on your car.
    1985 Mustang 5.0 coupe - dad's
    1983 Mustang GT sold deeply missed
    1981 Mercury Capri sold, not so missed (too far gone)
    1991 LX 5.0 vert sold
    2000 GT 75 mm TB, PP upper plenum, CAI, x pipe w/flows, SCT xcal 2 with a BAMAchips custom tune
    Sep 2002
    Western NC/East TN
    07 CVPI? You on the job? Never heard of a department not keeping a car for at least a year.
    -Zach
    Looks like they will work well enough as spares.
    What is the original application again?
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    Oct 2004
    San Diego, CA
    Quote Originally Posted by Chuck W View Post
    Dodge Magnum / Chrysler 300.
    Hi Scott,
    Thanks for being the Guinia pig on this. Looks great! I'm going to get a set for my '83 2 dr sedan. The 215/65/17 should fit no problems except it'll throw my speedo off 5mph at 60mph. I like the civilian CV hub cap.
    Please refresh my memory, inorder to use the CV hub cap one needs the CV lug nuts?
    Dean T
    Oct 2004
    San Diego, CA
    Yes, you'll need the special Ford collared lug nuts that came on Rangers, Explorers, Vics, etc. Should be fairly easy to find.
    FEP Member rbmead86's Avatar
    Dec 2004
    Lithia Springs GA
    LTDScott, Do you have a side pic of the car with the chrome caps on?
    Have You Registered your GT?
    www.mustanggt.org
    1986 Mustang GT Vert
    1985 Ford LTD SSP
    1977 MGB Vert
    Oct 2004
    San Diego, CA
    Quote Originally Posted by rbmead86 View Post
    Close as I've got...
    Oct 2004
    San Diego, CA
    Blurry photo from a Mustang cruise today
    FEP Senior Member quarterstang86's Avatar
    Oct 2003
    A t l a n t a, GA
    I like it! The lower profile tire looks good on those from a deceptive point of view. The cruise pic is awesome and would be by new avatar for sure if I were you. It says so much being different like that amoungst a pack of mustangs. Do you think these wheels will work with the common 5 lug swap Lincoln rotors or will they have the same issue with caliper clearance vs. the sealed hub 94-up stuff.
    Oct 2004
    San Diego, CA
    Quote Originally Posted by quarterstang86 View Post
    I honestly don't know about the Lincoln swap. I thought the only drawback to the Linc swap is that the center cap could not be installed on some wheels with that setup due to the tall dust cap.
    FEP Member scbolt's Avatar
    Aug 2007
    Birmingham, Alabama
    LTDScott,
    It looks like you've got a great road car there.
    A few years back we had a black 85.
    If I knew about this board back then i'd kept it.
    Randall
    78 Fairmont Sedan
    408/t5/8.8-3.73
    81 Fairmont Wagon
    5.0/t5/8.8-3.55
    FEP Member carbed87's Avatar
    Sep 2006
    that city in CO where the building looks like a whistle
    where are you getting these btw...
    86 coupe:
    turbocoupe rear with 3:73's and rear disc
    87-93gt spindles and rotors, lincoln calipers
    3g alt conversion
    MGW shifter (orange handle)
    93 cobra rims (black with polished lip)
    offroad h with dumped spintch pro-streets
    Oct 2003
    A t l a n t a, GA
    Quote Originally Posted by carbed87 View Post
    Scroll down to post #12. I linked the original post so you could read through it.
    http://vb.foureyedpride.com/showthread.php?t=53679
    FEP Power Member 86REDGT's Avatar
    Jul 2005
    Detroit, MI
    I like it
    What is the BS on the Dodge rims?
    86 GT vert - Bright Red/Grey Black top
    89 GT hatch - Bright Regatta Blue/Grey
    90 5.0 vert - Light Titanium/Red No top
    90 GT vert - Light Titanium/Black Black top
    91 5.0 notch - Medium Titanium/Black (wife)
    91 5.0 notch - White/Red soon to be black int
    Oct 2004
    San Diego, CA
    Quote Originally Posted by 86REDGT View Post
    I like it
    +25mm offset. Not sure what the equivalent backspacing would be.
    Southeast Texas
    Quote Originally Posted by LTDScott View Post
    If they are 7" wide rims that would put the backspace at about 4.5".
