Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
    I attempted that when I installed efi in my Fairmont. The shop doing the modification said they couldn't fit the bigger lines into the top of the sender. So we kept the stock sender for the fuel gauge and blocked the fuel lines. Then installed larger lines for supply and return directly into the tank. I think I paid around $150 to have it done. I'm running a frame mount pump though.
    That’s a good idea!
    I have seen people use bulkhead fittings and blocked fuel lines like you said. Something like this-
    I could always try and fabricate something, thanks for the suggestion!
    Mar 2013
    Where the Navy sends me...
    I also have the orange duckbill.
    it’s just way down at the bottom of the tank, not way above it like in that video
    Interestingly enough, user "5.0 bird" just posted about replacing the fuel pump and hose in his '84 Tbird. It, too, has the return line all the way to the bottom of the fuel pump assembly - http://vb.foureyedpride.com/showthre...=1#post1920987. It's unfortunate that Ford chose to go with the short return pipe on the Mustangs, and surprising it took people/businesses so long to figure out that's suboptimal and offer an aftermarket upgrade.
  3. #28
    Jul 2009
    Chicago, south subs
    That’s a good idea!
    The red cap is -6 return. The greenish cap is -8 supply
