Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 99
  1. #26
    FEP User
    Apr 2008
    Alberta, Canada ( optional shipping to Idaho Falls, ID )
    Default missing page..
    Quote Originally Posted by Mike Croke View Post
    Please right click and Save As... with these. You will need Adobe Acrobat Reader as they are in PDF format. The diagrams have been scanned from the originals which were on sheets approximately 12" x 24". Thus, when each sheet is initially opened, the quality may seem poor until the image is zoomed.
    1979 wiring diagram 1.2MB
    1980 wiring diagram 1.2MB
    1981 wiring diagram 1.3MB
    1982 wiring diagram 1.2MB
    1983 wiring diagram 1.1MB
    1984 wiring diagram 1.5MB
    1985 wiring diagram 1.9MB
    1986 wiring diagram 2.2MB
    these are great but diagram 11 ( page 12 is missing from 1985 wiring diagram)
    I have some really bad gif files of the missing info but i'd like to fix that file.
    thanks
    Johnjohn
    foxfixin...buddy's 85 and 84 and rollin in my 86
    oh, and my lawyer friend took viagra and he sez it makes him taller..
  2. #27
    FEP User
    Apr 2008
    Quote Originally Posted by 85CapriGS View Post
    Thanks for the diagrams Mike! Any idea why page 12 in the 85 manual is black?
    Ditto!!!
  3. #28
    Thanks. The 79 diagram helped me with the wiring gremlins.
  4. #29
    Great work. I found the "bedsheet" style diagrams at the dealership that I work at and these will be a great asset! Thanks
    Bill
    Beater ('82 Capri No Eng/NoTrans)
    Wife's Project Car ('83 Vert Stang GLX No Eng/NoTrans)
    Cinco ('88 Hatch Stang LX 5.0L/Manual)
    Calypso Green ('92 Hatch Stang LX 2.3L/Manual)
    '13 Ford Flex Platinum (Hers)
    Husband & father of 3 girls
  5. #30
    Feb 2004
    Whitinsville, Ma
    Thank you very much!
    '84 GT convertible, Oxford white, CFI to carb swap, AOD
    '83 GT, T-tops, Bright Red, 65K original miles, 2nd owner; '85 roller cam engine; 8.8 w/3.55s; ROH ZR-6's
    '88 LX 5.0 Notchback, 55K miles, 3.27's, Mach 1 suspension, 5 lug conversion; Saleen ARE 229 wheels; Flofit seats; Vortech S Trim, 42# injectors
    '89 Saleen clone, 3.55's, SN95 rear discs, SVO front discs, 9L white, ARE 229 5 spoke wheels, complete Flofit interior and Saleen gauges; Maximum Motorsports Panhard Bar;
  6. #31
    Sweet! God knows without these diagrams I'd have to press the horn to turn my lights on! Thanks!!!!
  7. #32
    bad ass thanks a bunch i have been trying to pin one down.
  8. #33
    Quote Originally Posted by DocTheAce View Post
    - Scott -
    • PAST CARS
    • 84 Capri
    • 96 SHO
    • 88 Mustang GT
    • 87 Mustang GT
    • 79 Capri -351W
    • 79 Mustang
  9. #34
    New User
    Dec 2008
    Cape Coral, Florida
    Default Not sure of the 86 diagram?
    Hey all, I am glad to be a part of a rare group. I can say that in my area, there are only two stangs like ours in a 45 mile radius. And I own one of them. So, here's my problem. I have an 86 GT 5 speed. I was in the process of converting it to mass air. I was out obtaining the new harness and my boy thought we would no longer need the old one so he cut it at the firewall. I have frantically searching for a new one. When I came home and told him we were cutting the mass air section from the new one of course he felt bad. Damage done. So, I came on here, found the thread showing the diagram for the 86, because I thought I could some how make the harness from the 92 I bought work, However, my old harness has two plugs by the firewall and once the cut harness was removed it left the twolugs being the female ends. The new harness has one, and is also a female not to mention different color coded wires. Everything else appears to plug in. On the schematic, I did not see these two plugs and therefore have no idea where to go from here. It will be a shame to go carb'd. Anyone got ideas. Thanks I have attempted to upload pics of the problem.
  10. #35
    Thanks Mike! BIG help.
    85 Mustang GT
  11. #36
    Can be usefull ...
    Here's a pin-out of the two circuits behind the dash cluster for '79.
    Left and Right are named according to the contact position on the circuit while looking it installed on the instrument cluster (as you would see the graphic below)
    • Green circuit
      • G1 : tach ground
      • G2 : tach signal
      • G3 : tach +
      • G4 : temperature sensor
      • G5 : ammeter in ?
      • G6 : ammeter out ?
      • G7 : fasten-belt + ?
      • G8 : fasten-belt - ?
    • Orange circuit
      • O1 : not used ?
      • O2 : oil sensor
      • O3 : IVR +
      • O4 : fuel sensor
      • O5 : instrument bulbs +
      • O6 : turn signal + left (so right turn signal when driving)
      • O7 : gnd
      • O8 : hi-beam +
      • O9 : turn signal + right (so left turn signal when driving)
      • O10 : brake bulb'
    I've checked twice ... but still might be able to make a mistake so if someone can take some time to validate ...
    '79 Pace Car 5.0 (well 4.2 until better days)
    '80 Capri 2.3 (sold ) - '79 Hatchback 2.3 (sold ) - '80 Notchback 3.3 (junk yard )
  12. #37
    i can't seem to find the courtesy lamp switches for the doors on the 86 file, it seems to lead to nowhere. i found them on the 85 file. is there any differences?
    1979 capri, a mess, 86 efi
  13. #38
    life saver
    BlackSniper's Stable:
    2002 Mustang GT(Totalled by a drunk driver)
    1986 Mustang 5.0L GT White Fully Stock...current project starts 5/28
    1991 Mustang 5.0L GT Black
  14. #39
    found the 79 wiring diagram one off ebay they are the best i have ever seen or used. got it cheap.
  15. #40
    Default Thanks- Vaccum
    This is perfect-Thank you. Does anyone have the same for the vaccum system and smog stuff for a 1986 GT 5.0 HO
    Again,
    Thanks you!
  16. #41
    Thanks! I should have paid more attention in high school Electricity class...there's lots of lines on them there pages
  17. #42
    Thank you so very much, This will help greatly in Fuel injection conversion
  18. #43
    has anyone tried to print these out on a printer is there a way to get them printed out on multiple sheets with out losing anything in the process?
    No Longer a 4I Owner
    But Have way too much 4I stuff Collecting Dust.
  19. #44
    Quote Originally Posted by theemustangman View Post
    I'm sure you could print them on 8x14 sheets of paper, telling the printer that's what your using, but you may have to squint hard to see a lot of detail.
    MY GARAGE | SUPPORT THE 2.3
    1982 Mustang GT T-Top
    1993 Reef Blue LX 2.3 5spd
  20. #45
    good job mike!! you are the "go to" guys!!! (and probably the only guy in the country who has this!!!) Thanks again...
  21. #46
    just fyi, pg 11 on 1983 is blank (black) too. is there a page missing?
  22. #47
    one problem do you have a wire harness for idiots????? i dont know how to read this! please help me lol
  23. #48
  24. #49
    Default Great Info Share
    Have an 86, but saved em all! You never know. Tons of Thanks
    1986 GT Convertible
    1986 Mercury Capri RS (1st Project)
    2007 F150 Fx4 - Daily Driver
    2004 Harley Davidson Fat Boy
    2004 F150 Lariat (Had)
    2001 F150 Lariat (Had)
    1997 F350 (Had)
    1997 Explorer Limited (Had)
    1993 Lincoln Mark VIII (Had)
    1984 1/2 GT 350 - "The Begining" (Had)
  25. #50
    FEP Super Member dburdyshaw's Avatar
    Jul 2005
    Florida (sometimes Arkansas)
    Quote Originally Posted by brendenwilk View Post
    Did you ever get the help you needed???
    13 Dodge Dart
    09 Shadow Sabre
    08 Caliber
    05 Aztek
    02 Avalanche
    02 Thunderbird
    01 Cadillac ETC
    98 Explorer
    96 Suzuki X-90
    89 Fleetwood
    89 Continental
    88 Town Car
    86 Silverado
    84 Fiero
    83 Town Car
    82 LN7
    82 EXP
    80 Mustang
    65 Continental
    62 Galaxie 500
    54 Packard
    Stock never goes out of style.
