Okay, Some more interesting stuff:
I understand what Mark was saying now. The Fuel pump relay harness plugs into the driverside door harness big time and one connector plugs into the tail light harness. [7/28/07 - This is not what Mark meant - I mistaken the Power Window and Lock harness as the FPR harness - the
Power Windows and Locks Harness plugs into the Driver Side Door Harness and the Passenger Side Door Harness]
There are three connectors left on the
[IGNORE]fuel pump relay[/IGNORE]Power Windows and Locks harness I do not know where they go yet. The big grey 8-pin connector I'm holding, the single male bullet connector, and the 2-pin connector with one PNK/WHT (?) layin on top of the [color=red][IGNORE]fuel pump[/IGNORE] (power window) relay. The wire color is hard to tell - the color is all run together. I have a hunch the connector in my hand goes to the dash harness and the bullet connector goes to the female bullet connector in the computer harness. I do have the dash harness, it's still installed in the '86 Mustang's dash. I'll have to get pics of it and the fuel pump relay connector next.
Remember the 3-pin mystery wire on the computer harness? I got the color wrong and corrected it in the previous picture and it hooks up to a connector in the tail light harness. Mark mentioned this previously.
12/01/10 update See Post #19 by Fordguy. He is correct, this connector plugs into the wire harness to the fuel pump relay. Note the wire colors and scroll down to the pics of the fuel pump relay harness.
Oh, BTW, the two connectors in the blue roll of tape in the previous picture are from the tail light harness.
There are a ton of connector here and I'm sure most go to the dash harness and some probably connect to the multi-function turn signal switch and some of the single wire connectors may go to the seat belt wire.
I haven't found the transmission wiring so I can't compare it to the dash harness connectors and someone stole the console from the wrecked '86 so I don't have a clue what those connectors look like unless the '84 console has the same wiring. I can grab the '84's console next and find out.
Jeremy, the program I used to insert the text came with my old digital camera I'm using. It's not the best (I can't draw lines) but it does okay.
RUH-ROH! I screwed up. Apologies to Paul. I put the HEGO (Oxygen sensor) harness on the wrong connector. The HEGO harness goes on the 8-pin with 5 wire mystery connector on the computer harness (near the TAB, TAD and EGR Control Solenoids).
That 8-pin connector I had the HEGO sensor hooked into? That goes to the 8-pin 7 wire connector on the driverside harness near the power booster.
Oh, and the spout connector is next to the TFI connector. Also, the '86 has one Self Test input connector.
Yup, I goofed. I'll have to reshoot those two pictures...
Thanks all for the input, it helps in the searching. I guess I should start figuring out what each of the wires are and where they go...
Dean T
