Results 1 to 11 of 11
    Default '82 Capri RS decoding
    Hi everyone,
    I'm pretty new here at the FEP forums.
    I just picked up an '82 Capri RS 5.0/4 speed
    71k original miles, red on red. T-roof.
    The only thing on the car that isn't original is the driver's seat.
    I was curious to see if the car should be kept original or if I should just build it into the fire-breathing monster that I've always wanted.
    I found the "ownercard" in the glove box, a piece of metal was attached to it with these numbers:
    1mebp67f2cf615697
    84 cd 19b z4a7d
    P.s. these numbers were on the door sticker:
    Body: 61D
    Ext: 27
    DSO:84
    Int. Trim:CD
    ?:A7DZ
    ?: 4RRHH
    Welcome to FEP! Sounds like a nice car.
    Body: 61D - Body type.
    Ext: 27 - Bright Red.
    DSO:84 - Not sure, Mercury is different from Ford.
    Int. Trim:CD - Red vinyl.
    A - Air Condioning.
    7 - AM/FM MultiPleX cassette.
    D - T-Roof
    Z - 3.08:1 Rearend gears, limited slip.
    4 - Four Speed Transmission - SROD.
    RR - Front springs.
    HH - Rear springs.
    Thanks a lot,
    I'm still unsure if I should keep the car original and just build it.
    The factory radio is still in it along with that amp switch next to the radio (still works)
    ...decisions, decisions....
    Just don't cut anything, and save your stock parts. As long as it's all bolt-ons, it's easily reversible.
    There's more info on the bucktag, though it's not as easily decoded. The bucktag is secured to the front of the radiator support, just behind the driver side headlights.
    I'm guessing that that car originally had TRX wheels, judging from the steelies on it now? Love that Capri-only hoodscoop too.
    VIN 1MEBP7F2CF615697
    1ME = Mercury, USA
    B = active restraints/manual seatbelts, no airbag
    P = passenger car
    67 = three-door hatchback body
    F = 5.0L V8 engine, 2V, 157 HP
    2 = check digit
    C = 1982 model year
    F = Dearborn, MI assembly plant (DAP)
    615697 = production sequence number (~15,697th 1982 Capri produced)
    Body 61D = three-door hatchback
    DSO 84 = Home Office Reserve
    Int. Trim CD = low-back vinyl bucket seat, Medium Red
    7 = AM/FM stereo cassette
    Z = 3.08:1 rear gearset w/ Traction-Lok differential
    RR = D9BZ-5310-R front springs
    HH = D9BZ-5560-M rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Thanks, I really appreciate your input.
    I just had the car up in the air today to further inspect it.
    Looks like EVERYTHING is original under there, right down to the shocks/springs and brakes!
    I can even read the part number on the muffler.
    I would assume that it used to have the TRX wheels, I wish I had a set to put on it now.
    I'll have to get the numbers from that buck tag, Thanks again guys.
    I guess that my ultimate questions is this: Should I bring it back to 100% stock and hope that It'll be worth big money one day, or should I just do whatever I feel like? (change the interior color, stereo, wheels, engine/tranny/rear end swap)
    Hey everyone, I just got the Bucktag info:
    CAPRI
    615697 61D F TR 035
    277 DF ST
    AC 05 HB S
    CRS DL MOD 07 V
    ELECTRIC-D NLR 12 (the 12 is at an angle and not in the same type-face)
    I typed it out line by line as it appears on the tag.
    Thanks in advance for the help!
    CAPRI = model
    615697 = production sequence number (last six of VIN, ~15,697th 1982 Capri produced)
    61D = three-door hatchback body
    TR = T-roof
    035 = unknown
    27(7) = Bright Red exterior paint
    DF = unknown
    ST = unknown
    AC = air conditioning
    05 = unknown
    HB = heated back glass/rear defrost
    S = speed/cruise control
    CRS = Capri RS trim level
    DL = power dooor locks
    MOD = manual overdrive (four-speed SROD) transmission
    07 = hood scoop ?
    V = unknown
    ELECTRIC = unknown
    -D = Medium Red interior trim color
    NLR = unknown
    12 = unknown (probably someone's personal stamp for QC)
    Thanks to FoxChassis and grabbergreen84, I've got all of the options and features that you guys have decoded for me.
    Now....onto another forum to find some NON-red interior pieces.....
    Thanks again!
    FEP Supporter 75coug's Avatar
    Mar 2003
    Van Alstyne, Texas
    Quote Originally Posted by skulljab View Post
    It will not be worth big money for a long time, if ever, because that's just the way it is with these cars, unfortunately. I would still go the original route with a car such as yours, however. There are plenty of previously-molested cars out there that can be further modified, while the number of originals is dwindling rapidly.
    Robert
    1986 ascMcLaren SC 5.0 -red
    1985 Capri GS (w/ 5.0) - red
    1985 Capri 5.0L - black
    1984 ascMcLaren SC 5.0 - white
    1984 Capri GS (w/ 5.0) - white
    1983 Capri RS Crimson Cat - red
    1982 Capri RS Black Magic - white
    1982 Cougar wagon
    1982 Mustang GT - red
    Thanks again!
    What's wrong with red? If it's restored right, it looks awesome!
    -Mike
