Page 1 of 4 123 ... LastLast
Results 1 to 25 of 81
    Mike Croke
    Guest
    Default It started tonight
    I've been tinkering with our '84 Turbo RS here and there and got it to start tonight. Only ran for a few seconds because there's no coolant yet, one fuel injector is leaking and I ran out of daylight. It still needs the LA3 swapped in, the FMIC installed, coolant added, timing set, etc. Also, I need to get some boost controller on so I can up the boost and an adjustable fuel pressure regulator so I can tune it.
    So this is what it will have when done:
    - lightly ported head with big valves w/ stock slider cam
    - LA3 computer, big VAM, brown top injectors
    - FMIC
    - 3" down elbow from Stinger
    - 3" downpipe into 3" Hooker Max Flow muffler
    - stock T3 .63/.60
    - some way of jacking the boost up
    - some way of adjusting fuel pressure
    Yay.
    Machine your own
    Neither here nor there
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
    Thats awesome Mike!
    Skye said you were going to town on it...woohoo
    No sound/video clips?!?!?!
    FEP Super Member anthonydalrymple's Avatar
    Nov 2004
    Salt Lake City, Utah
    Keep it up; sounds lke a screamer is in the making! Oh, and progress pic's are needed or this thread must die.....
    '89 5.0 5-speed 'vert, seeing rust for the 1st time in it's life as well as 4,500+ elevation....
    Earl Ingstad evlgt85's Avatar
    May 2002
    Phoenix, AZ
    Blog Entries
    4
    He's out there with the timing light. I'm not sunscreened and am still working on my coffee. I'll wander out in a bit, perhaps. The official FEP camera is pretty well jacked up, I'll see if I can get anything on Mike's camera. There's nothing much to look at, its a dirty and abused and neglected old thing. It's in desperate need of suspension and brake work, too.
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
    Quote Originally Posted by evlgt85 View Post
    We want pics of the CAPRI not MIKE
    Mike Croke
    Guest
    I am abused and neglected. I'll ask you keep the dirty part between us, sweetie. (Skye NOT Jeff)
    There's nothing visible except the Forced4 air box setup. No FMIC yet. No adjustable fuel pressure regualtor or boost controller. Otherwise stock appearing. See http://mc-machine.com/crokes_pics/v/TurboRS/ for pictures so far.
    Got the LA3 swapped and timing set. Runs better with 10* BTDC than last night with 10* ATDC which was the best I could eyeball it during reassembly. Still have the leaking injector. Also added coolant and have a substantial leak from somewhere around the lower intake. I'll take the intake apart again to see what I did wrong. But not now, by 8am, the car gets too hot to touch sitting in the sun.
    http://www.boostvalve.com/ go here for a boost valve or make your own
    loutheplumber made his . throw a tarp up to block the sun and skye stop abusing mike and let him finish the RS
    1983 Capri RS Turbo
    1986 Bronco 351ho
    VP Berks County Mustang Car Club
    http://www.cardomain.com/ride/2462250
    Capriman86's Avatar
    Mar 2003
    N.Smithfield, RI
    Quote Originally Posted by Mike Croke View Post
    phewww!
    I was all worried
    Glad to see your making some progress on the RS bud.
    Good work
    FEP Super Member AT6svo's Avatar
    Oct 2003
    San Diego, CA
    Sounds like progress is being made. The coolant leak is probably any of of the myriad of hoses that run to/from the oil cooler and lower intake manifold.
    Did you guys need a hood for a Capri, there was an oxidized tan one at the yards I went to this weekend. It was straight & no rust.
    -Mike Malone
    69 Mach1, 81 LX, 83 GT Turbo, 85.5 SVO 9L, 86 SVO 2A, 86 GT, 90 LX 5.0 - and a badass 84 LTD Wagon
    May 2002
    Phoenix, AZ
    Blog Entries
    4
    We're in need of a flat one for the white RS. The Turbo has a stock profile CF/Kevlar waiting for it.
    FEP Senior Member loutheplumber's Avatar
    Apr 2005
    Mc Donald PA.
    is that a aluminum 90* fitting on the turbo
    1985 Capri GS 2.3l turbo
    1988 Ford Thunderbird Turbo Coupe now lives as power plant in 1990 Jeep Wrangler
    2011 Dodge Ram 2500 Cummins
    1959 Ford 871 Select-o-Speed
    "You Can Tell The Men From The Boys By The Price of Their Toys"
    Quote Originally Posted by loutheplumber View Post
    AN fitting...image link doesn't work btw cause its a url
    Mike Croke
    Guest
    Aluminum 90* fitting for the oil supply line. 1/8" NPT into the turbo and -3 AN flare to the braided line. The line then goes around the head to another fitting that adapts the -3 AN flare to the double flare on the boss thingy where the oil pressure sending unit is.
    How are the engine grounds btw?
    Mike Croke
    Guest
    Grounds?
    Baseball field?
    The intake to body, bellhousing to body, chassis to engine block grounds.
    Mike Croke
    Guest
    I've done nothing with the grounds. Why the concern?
    In the case that they were frayed or the like.
    Mike Croke
    Guest
    Frayed ends of sanity?
    Sanity is a illusion the government wants you to believe in!
    Mine going from the intake to the body was bad looking on one end and has like 3 strains connecting it to the rest.
    Mike Croke
    Guest
    There was no ground from the intake to the body that I saw. I know the EFI 5.0 cars have a grounding wire in the injector harness but I didn't see any such wire on this car.
    don't forget the ground wire on the turbo
    1983 Capri RS Turbo
    1986 Bronco 351ho
    Apr 2005
    Mc Donald PA.
    you know i dont have one of those and my car runs fine
    Mike Croke
    Guest
    The coolant leak is coming from the lower intake between runners #2 & #3. Small pinhole. So I'm waffling getting this one fixed or getting a new lower.
