How do you decode the Doortag, I have a Picture. All I have is the Paint Code, the VIN Number, and the Body Code thank to FoxChassis.
Any Help Is appriciated.
Own: 1979 Mustang Ghia 200CI I6(in Process of Restoration)
Have Access to: 2002 Ford Mustang GT 4.6L V8 Laser Tint Red, Leather Medium Parchment Interior, 3.27 Locker Rear End, Mach 460 Sound
VIN 9F04T260638
9 = 1979 model year
F = Dearborn, MI assembly plant (DAP)
04 = two-door Ghia notchback body
T = 3.3L I6 engine, 1V, 85 HP
260638 = production sequence number (approx. 160,638th '79 Mustang produced)
Exterior Paint Colors 1C = Black
DSO 28 = Louisville, KY district sales office
Body 66H = two-door Ghia notchback body
VR [blank] = no vinyl roof
Mldg B4R = Black body side moulding w/ Green insert
Int trim FA = vinyl and cloth low-back bucket seating (F), Black (A)
A/C A = air conditioning
R 4 = AM/FM stereo radio
S [blank] = no sunroof
AX 8 = 2.73:1 axle ratio w/ conventional (non-locking) differential
TR W = C4 automatic transmission
TR YY = D8BZ-5310-AT front suspension coil springs
TR LL = D9BZ-5560-N rear suspension coil springs
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
Thank you, you don't know how much this helps me! I'm 18, Fresh out of High School, and my First car!
Do you mind if I take a copy of this label? I may use it for an online decoder.
If this helps others with their Doortag, Go right ahead. Just please make sure you blur my VIN and Build Date.
All codes will be removed from the tag. In their place will either be a text box to enter a code or a drop down menu to select a code.
Thanks!
your welcome, I hope this helps a lot of people decode their Doortags.
