Page 3 of 3 FirstFirst 123
Results 51 to 56 of 56
  1. #51
    i just looked at mine and it said: 3L08 88 6C03
    it looks as tho i got the original rearend in mine according to the decoder
    Brandon
    If you ain't first your last!
  2. #52
    Not sure if you are still looking for this info. But my 86 Capri has this tag #:
    201A
    SL73 A886F09
  3. #53
    Sorry, I jumped to the end of the post and didn't see you were done.
  4. #54
    I am going to add a new axle tag decoder to the list of other decoder I have so I need some new tags to verify data, especially from non-5.0L Capri/Mustang models. Thanks.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
  5. #55
    1979 Mustang Cobra 2.3T
    Build date 10/5/78
    First line similar to axle tag format, thread post #16 by paul78zephyr
    Second line similar to axle tag format, thread post #36 by Hissing Cobra
    Tag format partial change over?
    WGX-HX 8IB
    3.45 7.5 284B
    Guess: 8IB is the old coding used up to 12-78? Changed 1-79 to include day?
    8= 1978
    I= ninth letter-September
    B= line? shift?
    3.45, 7.5 284B No V or S prefix found.
    284?
    B?
    More mystery codes like on buck tags.
    Just for comparison, adding 93 Ranger 7.5 tag Build August 1993
    The later 90's? tag format
    Top line= S362A (7.5 conventional)
    Bottom line= 3.45 7.5 3G30 (1993 July 30)
  6. #56
    It looks like the tags with the period in ring gear diameter don't have the axle plant code preceding the tag number. I have seen one other like yours. It's from a 09-78 Cobra...
    WGX-BX 8IA
    3.08 7.5 279A
    It looks like in mid 1979 the period in the ring gear diameter disappeared, the tag number was preceded by an axle plant code, and the date code changed from year/month/week to year/month/day.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
