I'll be getting a dyno run soon to help show what I need, but a lot of you have my same combo, or similar and get GREAT times.
I constantly read about the low 14 second bone stock fox's, and I'm getting those times with a LOT of mods. Last night my buddy with a bone stock notch with 4.10's and drag suspension tied me every bit of the way....
so although I'm close to 14 flat/ late 13's, I don't feel that's good enough compared to what a lot of "stock" stangs have done.
last night I got a 14.9 with a best 60' of 2.44 this is at elevation, so corrected it's about a 14.5. my mph was 95, which should be higher I guess if I wasn't at elevation. I have MASSIVE wheel hop and tire spin, and I'm going to be working on fixing all that this week (stiffer shocks, air bag in the spring, and quad shocks.. I have none right now) and buying sticky tires.
so the suspension work will no doubt get me down to a mid 14, maybe lower, corrected to 14 flat maybe a little better, but I feel I should be deep in the 13's.
When I raced the stock notch last night, once we got out of the hole, I didn't gain on him the entire quarter, and I fully expected to chase him down because of my mods...so this tells me my upper end is severly killing me, which I suspected. I have monster torque and low end power like never b4 with this animal, enough to feel like a low 13 second car, but then once it hits close to 4g's, the power starts tapering off.
mods are as follows:
bone stock fuel pump, 97 explorer motor with gt40p heads, a ported explorer intake (not too heavily ported, just cleaned up a bit) 1.7 roller rockers, SPEED DENSITY, HO MUSTANG cam/tfs valve springs, frpp headers, stock 19# explorer injectors,cat back flowmaster with stock 4 catted h pipe, u/d pullies, 65mm t/b and that's about it for power mods....i've got mm knock off lower control arms, frpp uppers and 3.73 gears.
I can't afford to start throwing money at all kinds of stuff that may or may not work.
i've heard I'm at the limits for the stock in tank pump, i've also heard I may get a lot of high end power from just swapping to speed density, but of course you've got the other side saying speed density is fine. I do plan on swapping to a tfs 1 cam soon, but I still think I've got a lot more power to be had with this HO cam, do I need 24 pound injectors??
what all have you run with similar parts as myself and gotten the best results?
oh yea, the car is a heavy vert
for comparison, my bro has an 86 ttop with a 96 gt40 explorer motor, and his only differences over my motor is he has a tfs 1 cam and a magnaflow x. He also has et street tires, and got a 14.4 last night, corrected to 14 flat or so. this is a VERY ****ty track, and it's hard to get good times there.
he has a best of 8.7 in the 1/8th, which is good for mid 13's right? His car is a bit faster, obviously, but I feel there is a lot of improvement to be had there also.
