My cam that is. I recently read an article in fordmuscle about how they installed a cam on a 460 that they thought was "straight up" but ended up being way off the centerline. I think I may have this problem. They said tell tale signs are not alot of low end power, more up top, and a very hot lower intake manifold. My car seems to have these problems too. I have the Ford Racing E303 cam and when I installed it I just lined up the two marks on the crankshaft and cam gears and reused the stock chain/gears and did not degree the cam with a degreeing wheel. Has anyone else had this problem before?
